more CB questions... - JeepForum.com
post #1 of 4 Old 07-26-2004, 09:06 AM Thread Starter
BigWaylon
tubework is cool...
BigWaylon's Avatar
CB is in route, should be here Tuesday (except I'm not "here", and won't see it til Friday)...but I have a few questions before it arrives...
Do all CB have an external speaker output?
I bought one (Cobra 19DXIII) that has a PA output, but will it also have an external speaker output? i.e. can I run both?
Still trying to decide where to mount it, but the couple ideas I do have would basically make the speaker on the CB unit itself useless...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #2 of 4 Old 07-26-2004, 10:07 AM
James04TJ
James04TJ's Avatar
No, all CBs do not have an external speaker out however most do and if you have a PA out it would be same to assume that you have a speaker out as well.
I have RadioShack's compact external speaker mounted in the corner top of my dash. I have two radios so I have one speaker in each corner.
James04TJ is offline
post #3 of 4 Old 07-26-2004, 11:27 AM
slimP
slimP's Avatar
If that is infact the model # of your CB, then yes it has a jack for the PA and for an external speaker.
PDF manual
Page 7 shows it.
2. PUBLIC ADDRESS: An external 8-ohm 4.0 watt PAspeaker may be
connected to the PASpeaker Jack when this unit is used as a public
address system. The speaker should be directed away from the
microphone to prevent acoustic feed-back. Physical separation or
isolation of the microphone and speaker must be employed when
operating the PAat high output levels.
3. EXTERNAL SPEAKER: The External Speaker Jack is used for
remote receiver monitoring. The external speaker should have
8-ohm impedance and be rated to handle at least 4.0 watts. When
the external speaker is plugged in, the internal speaker is
automatically disconnected.
Here's a place you may consider mounting the speaker.
External Speaker Install
--==('99 Tj Sport - In progress)==--
--==(Pride, Heritage, Tradition - The American Legend - JEEP)==--
slimP is offline
post #4 of 4 Old 07-26-2004, 03:51 PM Thread Starter
BigWaylon
tubework is cool...
BigWaylon's Avatar
PDF manual
Page 7 shows it.
perfect...thanks...
I like that mounting spot, and am also considering the front left corner of the windshield/dash...
Hopefully I'll get pics up in the next weekend or two...
Greg
Got a few questions breas1 Tires & Wheels 0 09-29-2008 08:58 AM
Questions about SYE for 05 LJ mike_dippert Engines & Drivetrain 8 09-19-2008 08:51 PM
5.9 questions cherojeep Engines & Drivetrain 7 05-23-2007 09:24 PM
4WD questions.... Wheels4 Engines & Drivetrain 6 04-15-2007 11:25 AM
Rim questions?? 711429 Tires & Wheels 3 03-29-2007 11:58 AM
