Mopar RB1 radio/nav unit issues - JeepForum.com
post #1 of 2 Old 06-11-2013, 03:18 PM Thread Starter
tjcasey
Hello all.
The PO installed this unit in my tj. I have occasionally had an issue when on startup the screen and buttons don't work but audio does. From this forum I found that this was a pretty common issue-fixed by turning the jeep off then on again.
Unfortunately the problem has now become permanent. Last week the jeep sat for extended periods with the battery disconnected and this happened immediately after. I sometimes get full functionality when the ignition is on but as soon as I start the engine the screen goes black and no buttons work. No count of turning on and off will fix.
I have checked the fuses behind glove box and under hood, all were good.
I pulled the unit and checked the connections, they looked good.
I also checked to see if there was a recessed reset button couldn't see one.
Any ideas?
tjcasey is offline
post #2 of 2 Old 07-31-2015, 04:02 PM
ricerocket336
I know this is an old post. But I just installed an rb1 in my tj and I'm having the same issue.. Can anybody chime in? It's Really annoying I would like to fix the issue
ricerocket336 is offline
