Mapping a Trail In Advance? Creating GPX Track Files For Your GPS Using Google Earth - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Mapping a Trail In Advance? Creating GPX Track Files For Your GPS Using Google Earth
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueBest deals on Yukon Gears at JeepHut.comNeed Ace Engineering products? JeepHut has you covered.
Unread 04-12-2014, 08:19 PM   #1
TrailRated2011
TrailRated2011's Avatar
2011 JK Wrangler
Has anyone done this successfully for off-road trails that you haven't been on yet? Does it work well?
This is totally new to me, I just heard-say that you can create a track using Google Earth, save it out as a KML file, and then convert it to GPX using GPSBabel. After that, you can use GPSBabel or the software supplied with your GPS to upload the track to your GPS.
Where do you suggest that I go online to learn more?
TrailRated2011
Canada - Nat'l Capital Region
Know your angles before approaching obstacles and
follow the general rule of off-roading, "Go as slow as you can, as fast as you must."
I'm on the Web: geres.ca
TrailRated2011 is offline   Reply With Quote
Unread 04-13-2014, 09:57 AM   #2
SnowdogMarc
I'm using this on my Garmin and it has most of the trails I've been on showing up.
http://www.ibycus.com/ibycustopo/
Only issue is that it only works on Garmin units.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
