#1 | |
looking for good cb radio
what kind of cb do u guys have and how do u like it???? im looking to get one and im not sure what to get. also is there any local stores like radio shack or something where i can get it at?
#2 | |
http://www.rightchannelradios.com/ They have great deals and great customer service. I have the Cobra 75WX ST with the Cobra external speaker and a KB 40 antenna. They sell kits like my set-up starting at $169.00.
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#3 |
try a local truck stop
i like cobra |
#4 |
i dont really have any local truck stops but im sure theres gotta b one around
#6 |
I have a Cobra 29 LTD and like it a lot. I would definitely recommend it to someone looking for a good radio. It isn't all that expensive either. I use mine with a 4ft. firestik antenna. The radio is a little large though and a bit heavy. There are still plenty of ways to mount it though. I used http://www.rightchannelradios.com/ to get all my CB equipment. I found that they are a great shop and have great customer service.
#7 |
I like the Uniden 510 or 520 (w/PA) and there are other models.
The most important part of the CB System is the antenna, then the coax, then the CB. Pay the most for a good antenna (Wilson, FireStik) and good Coax (Belden or Times MicroWave), then look for a CB. The Antenna Mount/Stud, get the Stud Mount that uses Ring Lugs to connect the Coax, better all around.
Scrambler82 Do it right the first time ! |
#8 | |
#9 |
Sparky's CB Shack has great customer service and he doesn't hack when he does a peak and tune on a radio. Height is might (as well as low SWR and a good install) so don't ever forget about the oldschool 102" whip although that'll get in the way bigtime. lol
#10 |
Here is a link http://www.sparkyscbshack.com/Home.html
I think Uniden makes the best CB's out there. |
#11 |
Another vote for AL at SPARKY"SSSSSSSSSSSSSSSS awesome radio performance and outstanding customer service.
#12 |
Clean installation
I installed the following:
An LED switch panel. From Cool-Tech an UltraMount CB Antenna System SKU: JK07001 $89.00 with concealed mount, antenna and coax cable. A cobra 75 WX ST remote mount. I ran the coax up behind the switch panel (it replaced the plastic rectangle above the transmission tunnel below the stock switches) and mounted the remote mount behind the new switch panel, drilled a hole in the switch panel for the microphone quick plug in. Unless the microphone is plugged in, nothing is seen. It is a clean look with no CB crap hanging on or under the dashboard. I only use the CB in Interstate driving or on trails.
"An appeaser is one who feeds a crocodile, hoping it will eat him last" Winston Churchill |
#14 |
Check this out, I'm looking for a radio I can hear well . http://webpages.charter.net/easytims/jeep.htm#CB .
What if the hokey pokey really is what its all about |
#15 |
check out the line of radios galaxy makes they are all top quality
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
