Looking For the Best GPS Road/Offroad - Page 4 - JeepForum.com
post #46 of 61 Old 10-15-2013, 10:53 AM
steeevo
I agree,
totally think gps phone apps are worthless.
steeevo is offline
post #47 of 61 Old 10-15-2013, 08:36 PM
macklamar
With a dedicated device, you could easily cache maps for the entire country, and still have the added benefit of storing music and also being a tablet for email and things when you do have wifi.
I'm just saying it's a semi plausible option for someone who doesn't want to drop $600 on a GPS set up :shrugs:
macklamar is offline
post #48 of 61 Old 10-15-2013, 11:05 PM
badtux
Originally Posted by MikeSD View Post
I guess I believe in using the right tool for the job. In my opinion, and I know there will be objectors to this, any GPS that requires a cell connection, is worthless. And I include that to mean "needs at any time".
A GPS, to be worth a damn, needs to be able to operate fully, without EVER needing a cell phone connection.
Then that's pretty much none of them. To transfer maps to any GPS that I own, you need an Internet connection. Which may or may not be a cell phone connection. I have the maps for most of California preloaded on my iPad the same way that I have them preloaded to my Magellan GPS unit, and in both cases it came in via the Internet (though the Magellan had to be hooked to my laptop to get the actual maps while the iPad sucked them down directly). I don't think you can even buy maps on disks anymore, that's so... 1990s.
Dog: Man's best friend. Cat: Man's weird reclusive roommate who poops in a box.
badtux is offline
post #49 of 61 Old 10-16-2013, 09:15 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I too won't use a GPS offroad that requires a cellular connection either. My street GPS receivers require a cell connection which is fine but those are useless where I offroad since there is no cell coverage in the remote areas I wheel in. Which is why I use a Garmin GPS offroad, it doesn't require cell coverage.
I made the mistake of installing a GPS 'App' onto my Android a couple years ago & marked a location with it so I could find my way back to it. Well, to make a long story short, it didn't work because by the time I wanted to use it, I no longer had cellular coverage so that 'App' no longer worked. Let me tell you, that sucked because I didn't have my normal GPS with me. NEVER will I ever use a GPS offroad again that I haven't veified first that it doesn't also requre cellular coverage to work.
Jerry Bransford is offline
post #50 of 61 Old 10-17-2013, 09:23 AM
Sherfjeep
2010 JK Wrangler
There is an app called every trail that does a decent job, without a cel connection.
Sherfjeep is offline
post #51 of 61 Old 03-12-2014, 06:12 PM
caprob
off-line Topos
Originally Posted by J33Ptj View Post
I have switched over to my Droid Inspire for all navigation use. For off-road, I am using an app called Backcountry Navigator (~$10) which allows me to import gpx files very easily and also download maps (both satellite and topo) to use when I don't have any sort of data connection. Cheap and very reliable solution if you have a smart phone and an Otter Box to prevent any sort of dust from getting in the phone.
We too use Back Country Pro. We do Overlanding in the US (off-roading from point A to B) and needed an off-line navigation system. I love BCP. As a professional super-yacht Captain I'm fully aware of marine nav systems but found it a small challenge to finally find a high quality off-line topo viewer that is easy to use, especially where we go without cellular service. I even bought the DeLorme in Reach PLB and tried it but like our Samsung Galaxy Tab3 with it's internal GPS standing alone. Marking USGS topos for download was a bit tedious but actually helped me learn the areas quicker. This system is very inexpensive as well. I will have a better idea after this late spring and all Summer in the Rockies starting with Overland Expo 2014 mid May near Flagstaff. Feel free to contact me at caprob@hotmail.com or here to discuss.
Keep Calm Jeep On!
Rob
= _____====
=[ [][],[_____
=l-\|\| - -OlllllllO-
() )-o () )--o--) )
caprob is offline
post #52 of 61 Old 03-14-2014, 02:40 PM
Ross
I have a Garmin Etrex Legend, you didn't need an internet connection to load maps into it. I also have a Lowarnce Out Back it is takes a mini SD card.
Here are some Lowarnce maps:
http://www.lowrance.com/en-US/Products/Mapping/
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is online now
post #53 of 61 Old 03-14-2014, 03:07 PM
badtux
Whether Lowrance put the maps on the SD card directly, or you downloaded the maps off the Internet and put them onto the SD card, is irrelevant. The reality is that once the maps are on the SD card, you no longer need the Internet to navigate.
Same thing with Backcountry Navigator. Once you put the maps on the SD card via the Internet you no longer need the Internet or a cell phone signal. And my iPad + Backcountry Navigator cost a *lot* less than one of those $1K+ big-screen Lowrance jobbers...
Oh -- I would call the Garmin maps that are distributed on disk "maps". Because they suck. To get good (raster) maps instead of the sucky Garmin maps that leave off most of the details you must pay for an Internet service and, uhm, *download the maps* to get them onto your eTrex.
badtux is offline
post #54 of 61 Old 03-16-2014, 10:35 AM
Ross
With the ipad of smart phone can you change your north, your datum, declination? If you use mulitiple maps this could be an issue, otherwise probably not.
Ross is online now
post #55 of 61 Old 03-16-2014, 12:43 PM
badtux
Depends what offroad mapping package you're using. Backcountry Navigator has a setting to switch between magnetic bearings and true north bearings. You can also switch between WGS84 and NAD27 datum types, and eight different coordinate formats from DDD MM SS.SS to OSRef. Is that what you're asking about?
badtux is offline
post #56 of 61 Old 07-13-2014, 08:29 PM
OzarkJeeper
I tried BCPro on my Samsung Infuse downloaded the proper maps and it work's. But is unreliable because in thick trees the phone will not hold the GPS signal from inside the vehicle. Guess I am gonna splurg and get me a Garmin Montana 650T and be done with it.
OzarkJeeper is offline
post #57 of 61 Old 07-14-2014, 01:35 PM
badtux
The Garmin Montana is a good GPS. I know. I have one (bought it last month). But a) it isn't magic, it won't hold a GPS signal under that circumstance either, that's because GPS signals won't go through trees nor metal roofs, and b) the screen is rather too small for vehicle use, even though it's larger than most other handheld GPS's.
badtux is offline
post #58 of 61 Old 02-01-2015, 01:39 PM
MikeSD
2009 JK Wrangler
I have a couple Garmin and have NEVER used the internet with them.
But when I said internet, I meant "while using the GPS". My GPS units have maps that came with the units, for all of America, Canada and Mexico. The only time I would ever need the internet, would be if I wanted to update them, one time operation only. I will NEVER be in a situation, while out, and see the popup "no internet connection" which I have seen with app programs.
Honestly, I think people who use app programs do for for "economy" not "gps quality or capability". But, to each his own.
Current: 2009 JKR (red), 2013 JKUR (Tan)
Prev: 2008 JKUR (silver)
IRLP Node: 4581 (Jeep)
MikeSD is offline
post #59 of 61 Old 02-01-2015, 07:03 PM
nrsource19
The iPad with Retina display has only one downside -- it's nowhere near weather resistant. Not an issue for my Jeep where the most that ever comes off is the rear windows, an issue for those of you who go entirely topless. Also, put a piece of plastic shipping tape over the big button (protect the button itself with something non-sticky) to keep dust out of it, because it can get sticky otherwise. Other than that, I agree totally with the above sentiment -- the iPad is about the same price as a high-end GPS, but has better maps, better resolution, better user interface, altogether is just a better GPS than a GPS.
A kit that enables Mirroring of Google maps on the MyGig screen while also unlocking it for video in motion:
http://www.icarkits.com/products/WVICH03M
nrsource19 is offline
post #60 of 61 Old 02-01-2015, 11:25 PM
badtux
Preloaded maps are preloaded maps, whether you are using Backcountry Navigator on an iPad or a Garmin Oregon hand-held GPS unit. I have both. The iPad lives in my Jeep so I have a *big* screen to look at when driving (actually, when stopped at an intersection trying to decide which way to go), and the Oregon goes with me when I step out of my Jeep to go hiking. With both, I pre-load the maps off the Internet onto the unit at home before I go out into the field. I don't even turn on the cellular or WiFi connection on the iPad when I'm in the field, because if I do it sucks down battery juice faster than the cigarette lighter power adaptor can provide it.
I know the "app" programs that you are talking about, the free ones that come with the phones, and they have nothing to do with what anybody here is talking about. They're worth exactly how much you paid for them.
BTW, I have since switched to Gaia GPS as my offroad in-Jeep app for the iPad, because it's easier to select regions to download into the GPS that way and they seem to download faster than with Backcountry Navigator. This program runs on the iPhone also, and also has an Android version. The main reason I still use the Garmin Oregon once I step away from the Jeep is because it is much more power thrifty than the phone. Even if you turn off the cellular, wifi, and bluetooth radios on the phone, the fact that it has a much faster CPU and bigger/brighter display makes it suck down battery juice much faster than the Garmin. The Garmin will generally last all day on a pair of AA batteries and then you swap a new pair in. The iDevices and Androids... you're lucky to get four hours of GPS use out of them.
badtux is offline
Advice on increasing on-road ride quality without sacrificing off road Lord_Xcalibur Wrangler General Discussion 15 12-15-2008 07:41 PM
do on road laws still apply offroad? jimG16 Wrangler General Discussion 45 08-29-2008 02:31 AM
Rough road hop on smooth road xxcyted TJ Wrangler Technical Forum 5 07-26-2008 11:14 PM
Best on-road/off-road performance 2" lift 32" tire combo Bryan_16 TJ Wrangler Technical Forum 18 08-15-2002 11:02 AM
Best shocks for on road and off road edelbrock? odie YJ Wrangler Technical Forum 2 12-25-2001 05:31 PM
