Quantcast Lights dimming, when sub hits. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Lights dimming, when sub hits.
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Closed Thread
Old 01-28-2009, 02:16 PM   #1
jimG16
Yes ive searched, I found some things, they were confusing. I have 4 KCs, a CB, and a 1000watt amp hooked up to the battery. Same battery since we had it, if that means anything. So I ask, better off spending $150 on a 2.0 farad capacitor, or a new battery?
jimG16 is offline
Old 01-28-2009, 03:09 PM   #2
mylt1
a cap is a waist of time, money and space and doesnt do a damn thing. new battery and new larger battery cables.
mylt1 is offline
Old 01-28-2009, 03:16 PM   #3
kboyts
Upgrade your factory ground wires/braids with 4 gauge cable
kboyts is offline
Old 01-28-2009, 03:35 PM   #4
GCool
OEM battery?
If so you need to upgrade your battery to like a Optima Yellow or blue top g34. Also you need to upgrade your OEM wire under the hood.
07 4 door X Unlimited
K&N , 2in BB , 33's
Kicker SS 5 1/4 components X2 ,Kicker ZX350.4 , Kicker Solo X 12 , Panasonic CDQ 800U, Sundown 3000D, NSB 90 X2
Thanks to the new sponsor Sundown Audio!
GCool is offline
Old 01-28-2009, 03:41 PM   #5
DixiesCJ3B
If you upgrade your battery and your still having problems i would look into using two batteries to keep from ruining your alternator
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Build Thread
Are You An Offroad Junkie
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
Old 01-28-2009, 03:47 PM   #6
gily25
Capacitor=band-aid...fix it right
1000w amp? Specs would be helpful but I def think this is a wiring upgrade issue. A 1000w max amp should have a minimum of 4 guage wiring for power and ground. If you got your amp kit at wal mart that is usually 8 guage. If you ARE using 4 guage or dare I say it smaller guage then check your grounds (as prev said). If ALL that is in place then you're looking at doing "the big 3"
gily25 is offline
Old 01-28-2009, 03:53 PM   #7
Scrambler82
Scrambler82's Avatar
1982 CJ8
I do not know for sure how to wire up the Amp the correct way but as kboyts has stated the grounds are important.
Maybe run a larger gauge wire for the power directly from the battery if not already done and add the same gauge ground wire all the way back to the battery not to the body/frame of the vehicle.
Also, the grounds on the electrical system itself may be getting loose or dirty; find the body grounding point and clean up the connections, maybe even add another large gauge wire from that point to the battery's negative terminal.
The basic grounding system in the everyday vehicles are poor at best, the only way to setup a good grounding system is to run a large gauge ground wire to two or three point and run all of your grounds to those points. The only exceptions to this is the larger amperage draw components like Amp, large HAM Radios, things like that, they should have their own ground wires the same gauge or larger than the power wires.
luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
Old 01-28-2009, 04:01 PM   #8
Chatham036
i have two jl audio 12's in mine and love having a louder system than imports. makes them look stupid after they talk too much crap. ironically i usually listen to country?!?!
but a capacitor will fix your problem... .5 farad stablizes ~ 500 watts
or you can spend hundereds on a dual battery system.
Chatham036 is offline
Old 01-28-2009, 04:03 PM   #9
96greenxjjeep
a CAP will just put a banaid on the problem, you just need to get bigger power and ground cable and connect the amps ground wire to the neg battery post and make sure you do not have any other cables or wires crossing over the amps wires
96greenxjjeep is offline
Old 01-28-2009, 04:11 PM   #10
Silver_Slipper
well larger grade wires will help but a cap will help too. i use to have 1200rms runnin to an orion back in the day and wired it up with 0 gauge, yes thats right 0 haha. the size of ur arm. and the lights would dim bad on big hits. i had a red topper in it. a cap will help but if u want it to go completely away i would go with atleast 4G wire, a cap, possibly a larger alt from like a truck, and a second battery haha. but any one of those upgrades will help u little by little
[CENTER] Wheel it like a rental car!
My Jeep and I both wave. :D
[COLOR="Silver"]Silver Jeep Club #37[/COLOR]
[COLOR="Black"][B]Nightcrew #021[/B][/COLOR]
|¯¯l,[COLOR="Silver"][___][/COLOR],
[COLOR="Silver"]l---L--[/COLOR][COLOR="Yellow"]O[/COLOR]lllllll[COLOR="Yellow"]O[/COLOR][COLOR="Silver"]¬[/COLOR]
()_) ()_)--o-)_)[/CENTER]
"The Jeep is America's only real sports car" - Enzo Ferrari
[QUOTE=MarkoPo;6689793]No, we all know in the beginning God created the earth and the Heavens. On the second day God created man and Jeep. Man had too much fun so God created woman. Man hasn't had near as much fun since.[/QUOTE]
Silver_Slipper is offline
Old 01-28-2009, 04:15 PM   #11
96greenxjjeep
the only way a Cap will fix this it needs to be 3ft from the battery
try this http://www.selectproducts.com/site/tech.php
Old 01-28-2009, 04:23 PM   #12
lancer27
if all else upgrade your altinator, that will help out a good bit.
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
Old 01-28-2009, 04:47 PM   #13
spyder6
Just violated my Parole
spyder6's Avatar
Originally Posted by 96greenxjjeep View Post
i just think some good woofers and some tweeters and call it good you dnt need a sub to have a good sounding system
i can fart in a can and make it sound good
you dont have a complete system unless you have all bases covered, which means you need a subwoofer to cover the bass section. no speaker in a jeep will ever be able to match the capability of a subwoofer. the only speakers that come close are 6x9's and even they fall short when you need it louder than they can make it.
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline
Old 01-28-2009, 05:29 PM   #14
PJL
Start by upgrading the "big 3."
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1~TPN~1
That's your cheapest solution and one that often helps.
It's not enough to bash in heads, you've got to bash in minds.
- Captain Hammer
PJL is offline
Old 01-28-2009, 05:29 PM   #15
jimG16
10 gauge wiring kit. I know I need a lower gauge, but is that the problem? Its a Kenwood KAC-7204 powering a dual 2 ohm alpine type R 10"
jimG16 is offline
Closed Thread
Glock Forum
