LED's Street legal - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > LED's Street legal
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 12-04-2013, 10:45 AM   #1
4dorwranglerlyf
LED's Street legal
I really want to buy these D series led lights from Rigid and use them on the road but I am not sure if they are street legal. How do I know if they are too bright?
link to the lights - http://www.rigidindustries.com/led-lighting/20211
4dorwranglerlyf is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 10:55 AM   #2
Kraxen
as long as you adjust them so they don't blind on coming traffic, I don't see why it wouldn't be a problem. I ran KC lights mounted on my windshield last winter for about a week till I hunted down an electrical problem I had that caused just my headlights to stop working. All I did was point them down an toward the shoulder of the road a little bit and never got "flashed" or pulled over for it. Where do you plan on mounting them?
92 YJ
95 YJ
Kraxen is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 11:25 AM   #3
biffgnar
biffgnar's Avatar
What do you need to use them on the road for? If you have a lighting issue on road address it with your headlights.
As to your question, you need to check local state law on vehicle lighting but generally onroad you can usually run headlights and a set of low mounted fogs (which the duallys really are not). Nothing high mounted.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 12:59 PM   #4
uberxj92
1992 XJ Cherokee
X2 on both. Go down to your local cop shop and ask them about legal lumens and candle power.
Remember this one good rule. If an item has a legal disclaimer on the sales description then you can't sue them for misuse and they probably aren't intend for anything other than what they're sold for.
In my area we write tickets for aftermarket lights alot.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 01:34 PM   #5
4dorwranglerlyf
I was going to mount them at the bottom of my windshield. The main reason for getting them is because the stock headlights suck.
Unread 12-04-2013, 02:12 PM   #6
biffgnar
biffgnar's Avatar
Then address the headlights as I said before. There are lighting and harness upgrades available.
I don't believe there is any state where running windshield mounted lights illuminated while on road is going to fly.
Also, even for offroad, I believe the duallys you linked are flood pattern. For windshield mounted you'd want spot pattern (which they do make).
Unread 12-04-2013, 02:35 PM   #7
uberxj92
1992 XJ Cherokee
Headlights are upgradable. I run the led assemblies. Omg worth every penny. Clean bright waterproof.
Unread 12-04-2013, 07:20 PM   #8
4dorwranglerlyf
What headlights did you upgrade to?
Unread 12-04-2013, 08:02 PM   #9
biffgnar
biffgnar's Avatar
LED options for headlights are either Trucklite or JW Speaker.
Unread 12-05-2013, 12:30 PM   #10
uberxj92
1992 XJ Cherokee
Amazon com trucklite .
Unread 12-05-2013, 12:36 PM   #11
Hefavitzen
1981 CJ8
If you do not want to build your own headlight relay harness's, send this guy an email. He can probably hook you up with what you need for a good price. Headlight.upgrade@yahoo.com
Hefavitzen is offline   Reply With Quote Quick reply to this message
