LED's Street legal - JeepForum.com
post #1 of 11 Old 12-04-2013, 10:45 AM Thread Starter
4dorwranglerlyf
LED's Street legal
I really want to buy these D series led lights from Rigid and use them on the road but I am not sure if they are street legal. How do I know if they are too bright?
link to the lights - http://www.rigidindustries.com/led-lighting/20211
4dorwranglerlyf is offline
post #2 of 11 Old 12-04-2013, 10:55 AM
Kraxen
as long as you adjust them so they don't blind on coming traffic, I don't see why it wouldn't be a problem. I ran KC lights mounted on my windshield last winter for about a week till I hunted down an electrical problem I had that caused just my headlights to stop working. All I did was point them down an toward the shoulder of the road a little bit and never got "flashed" or pulled over for it. Where do you plan on mounting them?
92 YJ
95 YJ
Kraxen is offline
post #3 of 11 Old 12-04-2013, 11:25 AM
biffgnar
biffgnar's Avatar
What do you need to use them on the road for? If you have a lighting issue on road address it with your headlights.
As to your question, you need to check local state law on vehicle lighting but generally onroad you can usually run headlights and a set of low mounted fogs (which the duallys really are not). Nothing high mounted.
Romney in 2020!
biffgnar is offline
post #4 of 11 Old 12-04-2013, 12:59 PM
uberxj92
1992 XJ Cherokee
X2 on both. Go down to your local cop shop and ask them about legal lumens and candle power.
Remember this one good rule. If an item has a legal disclaimer on the sales description then you can't sue them for misuse and they probably aren't intend for anything other than what they're sold for.
In my area we write tickets for aftermarket lights alot.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 11 Old 12-04-2013, 01:34 PM Thread Starter
4dorwranglerlyf
I was going to mount them at the bottom of my windshield. The main reason for getting them is because the stock headlights suck.
post #6 of 11 Old 12-04-2013, 02:12 PM
biffgnar
biffgnar's Avatar
Then address the headlights as I said before. There are lighting and harness upgrades available.
I don't believe there is any state where running windshield mounted lights illuminated while on road is going to fly.
Also, even for offroad, I believe the duallys you linked are flood pattern. For windshield mounted you'd want spot pattern (which they do make).
Romney in 2020!
biffgnar is offline
post #7 of 11 Old 12-04-2013, 02:35 PM
uberxj92
1992 XJ Cherokee
Headlights are upgradable. I run the led assemblies. Omg worth every penny. Clean bright waterproof.
uberxj92 is offline
post #8 of 11 Old 12-04-2013, 07:20 PM Thread Starter
4dorwranglerlyf
What headlights did you upgrade to?
post #9 of 11 Old 12-04-2013, 08:02 PM
biffgnar
biffgnar's Avatar
LED options for headlights are either Trucklite or JW Speaker.
Romney in 2020!
biffgnar is offline
post #10 of 11 Old 12-05-2013, 12:30 PM
uberxj92
1992 XJ Cherokee
Amazon com trucklite .
uberxj92 is offline
post #11 of 11 Old 12-05-2013, 12:36 PM
Hefavitzen
1981 CJ8
If you do not want to build your own headlight relay harness's, send this guy an email. He can probably hook you up with what you need for a good price. Headlight.upgrade@yahoo.com
Hefavitzen is offline
