LED 3rd Brake Light Problem - JeepForum.com
post #1 of 5 Old 06-06-2009, 12:19 PM Thread Starter
Jebussaves0
Tj LED 3rd Brake Light Problem
So I recently bought some lug nut LED lights to replace the stock 3rd brake light on my TJ. Here is the link to the exact ones I bought:
http://www.4wd.com/productdetails.as...0&partID=42556
After I initially wired them up they worked fine. It wasn't until I drove it for the first time that they stopped working and caused my stop light fuse to blow. I've replaced the fuse 3 times now and they keep blowing. I'm thinking it has something to do the lower resistance of the LEDs but I'm not sure. Any ideas?
2002 Jeep Wrangler Sahara | 4.0L 5spd D44/D30 3.73s | Hurst Shifter |
| Hummer-Style CAI | 1" Rusty's BL/MML | AA TC Shifter Bracket | 2" BB | JKS Quicker Discos | 33x10.50R15 BFG KM2s | Alpine CDA-9886 HU | OTRATTW Switch Panel | G.P.F. Rear Bumper | Metalcloak Overline Fenders
M416 Trailer | In Progress
Jebussaves0 is offline
post #2 of 5 Old 06-06-2009, 01:50 PM
SirGCal
RIP
SirGCal's Avatar
actually, my money is on the possibility that you've shorted something out during the install. Go over the wiring again. Something is shorting to ground.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 5 Old 06-06-2009, 01:57 PM Thread Starter
Jebussaves0
The "wiring" in question was simply cutting the + and - wires from the old light and splicing them to the 2 wires connected to the LEDs. I'll go over it again but given the possibility that the wiring is fine, any other possible causes?
post #4 of 5 Old 06-06-2009, 02:33 PM
SirGCal
RIP
SirGCal's Avatar
Sorry to sound rude or inconsiderate or anything, but the truth simply is; you changed something, then the problem appeared. Fuses blow when the circuits are shorted out. So 99% of the time, it's either the new device or the wiring has a fault. Really that just about the only possibilities here...
SirGCal is offline
post #5 of 5 Old 06-07-2009, 10:33 AM Thread Starter
Jebussaves0
That was neither rude or inconsiderate. I was just looking for something else to watch for while I checked the wiring. In any case, you were right. The wiring had shorted out where it was pinched by the spare tire. Thanks
Turn Signal and Brake Light Problem!! Ulumanati Audio, CB & Ham Radios, GPS, & Electrical 1 09-05-2009 10:53 PM
3rd brake light turned reverse light wingshooter2009 Audio, CB & Ham Radios, GPS, & Electrical 3 07-13-2009 01:55 PM
Crazy Brake Light Problem AlmoStok Audio, CB & Ham Radios, GPS, & Electrical 2 04-24-2009 05:10 PM
Tail Light or Brake Light Mount MCanavan Audio, CB & Ham Radios, GPS, & Electrical 20 01-26-2006 04:48 PM
