SO I've been doing lots off research lately and have learned a little about l.e.d lighting. My question is that since I am making all turn signals and eventually tail and the OEM 3rd brake light replacement bulbs
1). I plan on using (6) 5mm white diodes rated at
- FW 25mA
- FW supply 3.3v
- intensity 7000mcd at a 30degree view
2) Would this be more than bright enough for the amber OE lenses of the TJ
or do you think that (4) would suffice
these calculations are from this site which is sweet since you can put in how many diodes and what volt application its for:
LED series parallel array wizard
this is for (4) diodes
* each 220 ohm resistor dissipates 137.5 mW
* the wizard thinks 1/4W resistors are fine for your application Help
* together, all resistors dissipate 275 mW
* together, the diodes dissipate 330 mW
* total power dissipated by the array is 605 mW
* the array draws current of 50 mA from the source.
or should i do the (6) diode setup for each turn signal up front
-and of course I would replace my turn signal module with a l.e.d capable one.
As for my brakes those will come later I want everyone's opinion first, and must at least know something about l.e.d lighting please
