Quantcast kick panel speaker pods - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > kick panel speaker pods
Old 02-05-2010, 11:38 AM   #1
BigJake87
i know ive seen a thread on this before but im having some trouble locating it but anyways.. which would be a better option to choose. i plan on installing kenwood exceleron's in which ever one i decide to get.
1. mod pod with 5 1/4's
Mod Pod by Select Increments and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
or
2. Q Logic Component pod for a 6 1/2 component set
Jeep Wrangler Component Speaker Kick Panel [QL-K3014C] - $199.99 : Q-Logic Direct, Car Audio Speaker and Subwoofer Enclosures
BigJake87 is offline   Reply With Quote
Old 02-05-2010, 01:59 PM   #2
BigJake87
oh yea forgot to say my current setup,
soundbar and dash Kenwood Excelon KFC-X1300 Car Speakers at Onlinecarstereo.com
i also have vdp sound wedges with a 6.5" polk component setup but will be replacing them with potentially these Kenwood Excelon XR-S17P Component Speakers - Car Speakers at Onlinecarstereo.com
currently i only have the soundbar and wedges amped but im gunna rewire so everything is amped (can my amp can handle it??) Orion HP-4800 Amp: Multi-Channel - Car Amplifiers at Onlinecarstereo.com
then i have two kicker 10" cvr's powered by Orion HCCA-D600 Amp: Mono - Car Amplifiers at Onlinecarstereo.com
thanks for any answers provided.
Old 02-05-2010, 04:34 PM   #3
Sarge_
I installed Kicker 6.5" Shallow mount subs in the front kick panels. Carpet over the grill, and they're invisible, but the sound is quite a bit better than I had even hoped for.
I did line the chamber with sound deadening foil/rubber stuff and added some polyfill with spray glue as well.
IMO it's the best use of that space, as bass is the least directional of all frequencies, and you can install 5" separates in the dash.
'06 Unlimited Rubicon, Midnight Blue, 6M
Previous Jeeps
'00 TJ Sport 4.0
'00 GC Laredo 4x4 V8
'95 YJ 2.5L
Sarge_ is offline   Reply With Quote
Old 02-05-2010, 04:48 PM   #4
BigJake87
hmmm.... cant say that ive seen that done before. nice work.
Old 02-05-2010, 10:23 PM   #5
2003X
2003x
2003X's Avatar
wow thats insane.
I have the MOD Pods, they are awesome. When I have the doors off, the sound stays in the jeep. Much louder then I expected. Here are some pics.
I am running Alpine SPS500 speakers in them.
The Mod Pods are supposed to be screwed into the tub, but I used 3M double back tape so I can easily remove them to clean the carpet. The 3M holds them and they havent moved yet, and the Pods fit perfect.
That Q-logic one is nice, but I dont how it would look/ feel with the manual tranny pedal there. Also your foot is in constant contact with it I would think.
Big Axles and Big Tires!
My Build
http://www.jeepforum.com/forum/f22/2003x-tj-build-944608/
2003X is offline   Reply With Quote
Old 02-06-2010, 11:30 AM   #6
BigJake87
Well I have an auto trany so I wouldn't have to worry about the clutch pedal, but yea it does look like it would stick out quite a bit. I was more curious about speaker position/angle and how sound might vary between the pods.. I'm kinda diggin Sarge's idea though and might have to look into doin that, looks like a great way to utilize the limited space in the cab.. Hey Sarge if you have any pics of your driver side I would greatly appreciate it if you would post them.
Old 02-08-2010, 11:28 AM   #7
gily25
Sarge are those made of sheet metal? did you cut into the tub?
gily25 is offline   Reply With Quote
Old 02-08-2010, 11:41 AM   #8
Sarge_
Yes, I dremel'd the tub and used a 1/2 inch spacer, sealed it with some metal caulk and lined the cavity (extends all the way up toward the windshield) with sound matting, then spray-glued it and dabbed in some polyfill for good measure.
If you do it, also be sure to fill the holes at the base of the cavity (small openings at the bottom of the tub. (They don't look to be intended as 'drain holes', and I don't see any way for water to get down there from above, so I'm pretty sure it's save to fill them. I also checked with my friend who owns a high-end audio store who has done hundreds of these, and he says no water problems, no reason not to plug the holes).
Took a little time, but a very good result.
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Old 02-09-2010, 01:59 PM   #9
gily25
It's very similar to the set-up of a competitor andy jones. He has a midbass cut into the metal kick panel. His is in an altima so there's a plastic trim panel over it. Excellent install.
Did you do the driver's side as well?
Old 03-25-2010, 04:11 PM   #10
matikos98
2008 WK
that looks awesome!
i dont know what im doing, I'm just making it up as i go....
2008 Jeep Grand Cherokee Black on Black
http://www.jeepforum.com/forum/f197/2008-wk-audio-upgrade-1225123/#post11681011
This is Sold but you can still look.
http://www.jeepforum.com/forum/f11/my-very-slow-xj-build-843542/#post7807352
matikos98 is offline   Reply With Quote
Old 04-04-2010, 12:41 PM   #11
Peregrine777
Do you know if those Mod Pods accept a 6 1/2 speaker?
I wrote to Q-logic and they told me that there is plenty of clearance for the clutch pedal. They added that they have had nothing but positive feedback on the product, for what that's worth. A bit pricey, though.
Peregrine777 is offline   Reply With Quote
Old 04-05-2010, 03:36 PM   #12
gily25
You can find the q logic kicks on ebay for cheaper if you desire. You can also check out crutchfield a few times a year, they sometimes offer a deal when you buy 6.5" speakers at the same time. There's always the option of fiberglassing your own if you have the time and space to work.
Old 04-05-2010, 10:25 PM   #13
Peregrine777
Everything I found on ebay was list price or higher. I also went to crutchfield and they seem to carry every Q-Logic product except kick panels for Wranglers.
Old 04-07-2010, 11:37 AM   #14
gily25
I had found them on ebay before but maybe the store stopped carrying them.
I see they changed them a bit...(I had a local saved pic from when I considered them) the woofer sits further back on the floor now. I always figured the back of the kick was too open and it would just sound as bad as the dash speakers.
As for the mod pods...I had modified a set for use in my YJ and I hated them and got a centra pod instead. They just seemed to be in a bad location.
Glock Forum
