Keep blowing #8 fuse - JeepForum.com
post #1 of 3 Old 10-15-2009, 10:38 PM Thread Starter
Danbert
1983 FSJ Wagoneer
Tj Keep blowing #8 fuse
2000 TJ 4 cyl.
Heater only.
Blowing #8 fuse (fuse for heater control, blend door actuator,& fan relay)
When I replace the fuse, the heater and fan will run for a while then after a few minutes the fuse will blow.
Any advice would be greatly appreciated.
Danbert is offline
post #2 of 3 Old 10-16-2009, 07:59 AM
SirGCal
RIP
SirGCal's Avatar
Check behind your control panel...
Fixing Fault in TJ's Wiring for AC Control
That might not be your problem but, you're overdue for that failure and it's an easy check.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 3 Old 10-16-2009, 10:38 AM Thread Starter
Danbert
1983 FSJ Wagoneer
Right on. I will check that out. Thanks! Although I will point out that while I was replacing the stereo, I pulled the panel and did a hands on and visual check of the control panel. I was looking for heat stress to the plastic or any type of visible failure. (at the time the heater wasn't working at all and the owner thought he changed the fuse out for a good one.) Silly me for not verifying .
I will definitely put this upgrade on the to do list as I like to know anything I ride in is safe.
Any other ideas would be greatly appreciated.
Danbert is offline
fuse blowing claytonandson Audio, CB & Ham Radios, GPS, & Electrical 4 03-06-2009 06:36 AM
Amp fuse blowing, need help. jimG16 Audio, CB & Ham Radios, GPS, & Electrical 13 01-04-2009 04:29 PM
i keep blowing a FUSE usarmy0101 Audio, CB & Ham Radios, GPS, & Electrical 5 06-10-2008 02:42 PM
cb fuse blowing?? blacktjsport Audio, CB & Ham Radios, GPS, & Electrical 2 01-02-2005 04:53 PM
Fuse Blowing.... BuffaloYJ Audio, CB & Ham Radios, GPS, & Electrical 3 03-05-2004 07:27 PM
