KC lights relays buzzing - JeepForum.com
post #1 of 2 Old 01-13-2013, 07:57 PM Thread Starter
sprucelk17
I recently was driving down the road and turned on my 4 KC lights (2 long range, and 2 driving. All mounted on light bar. 2 seperate circuits, switchs, and relays) and noticed they didn't turn on! I also later noticed that one of the lights lenses was shattered (not sure if relevant). I knew that my battery terminals were very corroded and giving me trouble starting sometimes so I thought maybe they were too corroded to give the lights power (lights are wired directly to battery). I also have 2 more KC lights on the bumper that are also wired to the battery but work fine. So today I cleaned the battery terminals. When I put it all back together I went to turn on the 4 lights and both relays just buzzed! They probably did it before too when i was driving but I didn't hear it. What could be a reason for BOTH relays to be buzzing??
sprucelk17 is offline
post #2 of 2 Old 01-14-2013, 03:59 PM
Xpress
Perhaps the current is reversed inside, or water got inside, or perhaps the magnet has a short inside. All a relay is is an electromagnet, and they can fail from weathering. Have you tried to substitute another relay to double check?
All about that unibody life.
Xpress is offline
buzzing , kc , lights , relay
