KC Headlights - JeepForum.com
post #1 of 4 Old 04-24-2014, 01:07 PM Thread Starter
Madden_07
KC Headlights
Hey guys, I have an 06 TJ that's in desperate need of a headlight upgrade and as much as I would love to get some JW Speakers I can't quite justify spending that much money on them lol. I was wondering if anyone had any experience with these KC's I found, I figure anything will be better than what I have now. I've already done some research into the Hella E-Codes as well and figured I'd rather just play it safe and stick with DOT approved lights.
Any feedback would be great!
There's no replacement for displacement
Madden_07 is offline
post #2 of 4 Old 04-25-2014, 01:47 PM
CrustySprings
I used this:
http://www.quadratec.com/products/97009_500_07.htm
These have glass lenses and aluminum reflectors so you don't have to worry about melting plastic lights like KC's.
Also I used this wiring harness. It has two relays and ceramic connectors so heat won't damage them.
http://www.ebay.com/itm/370658138040
This setup works great and was easy to install.
258 cu. inch six, Team Rush ignition upgrade, T5, Dana 300, Superwinch lockouts, Black Diamond 3" suspension lift, greasable shackles, poly bushings, JKS quick discos, 32x11.50x15 Cooper STT's, American Racing 23 15x8 alloys, Uniden Pro 520XL CB radio, 2' adjustable tip Firestick antenna, Viair 460 onboard air system
CrustySprings is offline
post #3 of 4 Old 04-25-2014, 04:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy 100% glass E-Code H-4 headlamps, and upgrade the wire harness. Any headlamps that are plastic, or look car-show cool, will perform poorly. Unless you need DOT approved headlamps to pass state vehicle inspections, they should be avoided.
CJ7-Tim is offline
post #4 of 4 Old 05-02-2014, 02:44 PM
Needalife
I have those headlights (KC's) and they are better than stock. Pretty much plug them and and adjust.
For DOT approved they work good and are brighter than stock.
Jeeps, We like it dirty, rough, and wet!
Needalife is offline
