JL 12W6? are they worth the hype? - JeepForum.com
post #1 of 5 Old 11-05-2001, 05:04 PM Thread Starter
mytjnamedrex
Post JL 12W6? are they worth the hype?
well are they and what kind of box is the best?
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 5 Old 11-06-2001, 04:00 AM
AJ
Post
Jl's are expensive. But they are worth every penny. They are very versatile and will work well with just about any kind of enclosure, assuming it's sized right. They hit very hard and very clean at the same time.
The 6's are 6 ohm speakers and are designed to be used either singly, or in triples, to work with most amps. You probably don't have room to run 3 12's unless you don't ever use your rear seat. If you are really interested in JL's in your jeep, look at their stealthbox. It replaces your center console and has a JL 12 built into it. It looks stock, completely unnoticeable, which keeps your sub safe. It also sounds great even with a soft-top, and it even hits hard with the top down.
It is kind of expensive, but if you keep replacing subs and slashed soft-tops...
AJ is offline
post #3 of 5 Old 11-07-2001, 09:23 AM
vector_3
Post
A JL W6 is a sound quality sub. I plays bass very accuratly. If you want a sub that is really loud then go for a W3. The type of sub you buy depends on what you like as far as bass. JL's are great subs if you want something cheap but works great go for a W0. And if you have money to burn go for the new W7. As far as the stealth box AJ's right, it's a great investment. I'm not sure if you can get a 12 in a stealth box though for a '97. I think it's just 10's. I could be wrong though.
vector_3 is offline
post #4 of 5 Old 11-07-2001, 05:49 PM Thread Starter
mytjnamedrex
Post
Im thinking about 2 and downfiring one in a sealed box and one behind the seat in a ported (or sealed) box firing forward. I found a way to rig a seat so I can downfire.. Anyways I was just wondering if they would be a good choice.
post #5 of 5 Old 11-13-2001, 12:33 AM
eltj
Post
Go with the W3. The sub performes as will as a W6 but has the VRC voice coil which will stand up to more abuse. Another thing that is over looked is that the W6 requires a biger amp to perform its best. In a jeep the best box is going to be sealed because on a ported box they require twice the air space. Your best bet is a down fire box with 2 10W3's the voice coil will depend on the type of amp you have but the 2ohm version requires the smallest box.
eltj is offline
Older JL Audio 12w6 monstermack Audio, CB & Ham Radios, GPS, & Electrical 7 11-06-2008 12:35 PM
worth of an 8.8 billyjp2 Tires & Wheels 1 09-01-2008 09:04 PM
worth it ? slav1north General Jeep & Off-Road Equipment 5 06-26-2008 03:23 PM
D44 .. Worth it ?? EG00TJ Engines & Drivetrain 9 09-06-2007 03:19 PM
