Jeep wont start sometimes.... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & HAM Radios, GPS, & Electrical. > Jeep wont start sometimes....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-21-2015, 02:26 PM   #1
xjquinnxj
Earlier today i went out to my cherokee and started her up for a little bit, did some cleaning, went to go start it again and it didnt start, seems like the starter,when i tried starting it all the lights on the dash went out. then 15 min later it starts wtf. Has a new battery and rebuilt alternator, i think its the starter. Any other ideasas to what my mystery may be ??
xjquinnxj is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 03:00 PM   #2
xrunndonex
1994 ZJ
Any codes via key dance
xrunndonex is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 03:09 PM   #3
TheDonk
1987 YJ Wrangler
How did the lights go out? Did they just turn off like on a switch or get gradually dimmer?
You could always try to jump the starter, or take it out and have your local parts store test it for you.
"Try not to become a man of success, but rather to become a man of value." - Albert Einstein
TheDonk is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 07:26 PM   #4
xjquinnxj
Originally Posted by TheDonk
How did the lights go out? Did they just turn off like on a switch or get gradually dimmer? You could always try to jump the starter, or take it out and have your local parts store test it for you.
i figured just for the hell of it id clean the battery terminals and sure enough it solved it, always gotta start with the simple things
Unread 01-23-2015, 07:36 PM   #5
TheDonk
1987 YJ Wrangler
Glad to hear it worked out for you. Definitely a cheaper fix than a new starter.
Unread 02-25-2015, 04:36 PM   #6
xjquinnxj
well after while the problem came back, i did start it by turning the key and shifting to neutral so i think it may be the neutral safety switch, i cant seem to start it that way anymore though, everything just goes out, when you go to start it you can hear the relay, ive checked the battery connections but i think my problem is many things, maybe the connection at the starter or the grounds
