Jeep not starting, help! - JeepForum.com
post #1 of 21 Old 04-23-2012, 01:29 AM Thread Starter
fufiloven69
Iv replaced so much, could it be my auto start? It will fire up for a second then just shut off. I bought it with auto start, but never got the remote. I've used the start button on the inside. My boyfriend came home from drinking and his friend left the driver door open all night in -40. Now it won't start.
It's a 93 jeep cherokee limited straight 6
fufiloven69 is offline
post #2 of 21 Old 04-23-2012, 02:26 AM
lauderdalechad
2006 WK
We need more info...make/model/yr/engine
Samething happened to my girlfriends sebring (same alarm system)...turned out to be a blown fuse for the pcm. Disconnect the battery for 30min and check all the fuses very closely ...start there and let us know the results
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline
post #3 of 21 Old 04-23-2012, 02:33 AM Thread Starter
fufiloven69
Thanks, will do!
post #4 of 21 Old 04-23-2012, 04:12 AM
JPNinPA
Did it have any issues when they drove it home or any symptoms before this?
Any off roading?
If he left the door open it could be as simple as a run down battery. Measure the voltage on the battery. It should be 12.6V.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #5 of 21 Old 04-23-2012, 07:14 PM Thread Starter
fufiloven69
[QUOTE="fufiloven69"]Iv replaced so much, could it be my auto start? It will fire up for a second then just shut off. I bought it with auto start, but never got the remote. I've used the start button on the inside. My boyfriend came home from drinking and his friend left the driver door open all night in -40. Now it won't start.
Ugh, even with all I have tried, Nothing works. Replaced the battery, checked fuses, tried grounding wires. What else can I do? I live over 100 miles from the nearest shop
post #6 of 21 Old 04-24-2012, 06:08 PM
lauderdalechad
2006 WK
This should do the trick...read the whole thread to get as much info as possible
http://www.jeepforum.com/forum/f13/h...our-zj-483020/
post #7 of 21 Old 04-24-2012, 06:10 PM
TMSquy
it does the starter crank?
TMSquy is offline
post #8 of 21 Old 04-24-2012, 06:11 PM
TMSquy
Does the starter crank***
TMSquy is offline
post #9 of 21 Old 04-24-2012, 07:48 PM
lauderdalechad
2006 WK
The op states that the car STARTS then dies after 2 seconds...that's alarm/ecu problem for sure
post #10 of 21 Old 04-24-2012, 11:26 PM Thread Starter
fufiloven69
All I can find in the driver door is a purple and pink wire as well as a purple and white wire, what to do now? I did find a purple and yellow wire under the glove box though. But Everything I read is about the driver side though.
post #11 of 21 Old 04-24-2012, 11:27 PM Thread Starter
fufiloven69
Yes, the starter does crank. And thank u everyone who is helping!
post #12 of 21 Old 04-25-2012, 12:12 AM
lauderdalechad
2006 WK
Where does the purple/yellow wire go to? On page two of that thread there is a good picture of the few plugs in the driver door and I believe it states which plug it actually is...double check the post and your wiring ...u have the same vehicle as the poster so there shouldn't be a difference in the wiring
Here is a better one...step by step
http://www.jeepforum.com/forum/f13/p...w-wire-483522/
post #13 of 21 Old 04-25-2012, 01:13 PM Thread Starter
fufiloven69
I'll try it today, wish me luck! I hope it fixes my problem. I sure miss my jeep! Will update soon
post #14 of 21 Old 04-25-2012, 01:33 PM
CHOMPAWHAMPA
1987 MJ Comanche
1987 comanche 2wd
i have a no start issue too. i have power but it doesnt start or turn over not even the click click click...ive been told it mightb a fusible link , a sensor behind the harmonic balancer ? or a dead soliniod any ideas anyone ?
CHOMPAWHAMPA is offline
post #15 of 21 Old 04-25-2012, 03:47 PM
lauderdalechad
2006 WK
Bad starter...try tapping on it with a hammer while somebody is in the car trying to start it
