Jeep Compass 2011 Battery Drained - JeepForum.com
post #1 of 2 Old 01-17-2012, 02:20 PM Thread Starter
jlek2012
Hi everyone.
I need your help!
I bought a Jeep Compass Limited 70th Anniversary in Chile that has a factory flaw which, official dealer has been unable to repair. Succinctly, the Jeep has an ignition problem and the battery has been replaced 3 times in 5 months of use.
The car failed for the first time with 140kms only 7 days after its purchase in August. The car did not start even though no accessory or lights where left on as suggested by the dealer. The dealer changed my battery. In October, with 1400kms the same defect occurred and Jeep dealer completely checked the car for 10 days determining that there was no abnormal battery consumption. They proceed to change it again mentioning that the battery batch could have had a failure. On December 24th, the car again does not start and the battery is completely drained. The dealer does not know or is not able determine the cause of the automobile electrical system failure. The pattern of total discharge of the battery is every 2 months (August, October and December).
Anybody have a clue of what's the problem?
Thanks!
jlek2012 is offline
post #2 of 2 Old 06-11-2013, 04:25 PM
caro
2012 MK Compass
hola, tambien soy de chile y me pasa lo mismo no respondio la concesionaria, no se si tu encontraste alguna solucion al problema a mi me dijeron que podia ser la caja de fusibles pero tiene otro nombre que no recuerdo , se supone que pasa toda la corriente del auto por ahi y esa estaria fallando, espero tu respuesta saludos
caro is offline
my 2011 jeep cuevas55 Tires & Wheels 0 10-24-2011 10:54 AM
Made a kill switch, now battery's drained. horuhe00 Audio, CB & Ham Radios, GPS, & Electrical 3 07-11-2010 07:57 AM
Installed a factory GM mirror into my Jeep. Auto dim, compass and temp. CETROV Fabrication Shop 8 11-21-2009 06:02 AM
6.5" subwoofers for Jeep Compass? robb01 Audio, CB & Ham Radios, GPS, & Electrical 5 02-02-2009 09:46 AM
TJ fluids all drained, what to put back in? (Transfercase) Duffboy Engines & Drivetrain 6 01-15-2009 06:18 PM
