Jeep Cherokee Master Window Switch - JeepForum.com
post #1 of 9 Old 05-24-2012, 05:12 PM Thread Starter
terzaghi
Hello, I've read about the master window switch in the Jeep Cherokee being a common problem. Here is my current situation:
I have a 99 jeep cherokee sport 4 door, bought 7 years ago. I have never been able to roll down the passenger windows from anything but the main driver window switch (likely due to the bad window lock feature that I have read about). within a year of ownership I lost the ability to use the power locks from all switches (must manually lock).
Within the last week, I lost the ability to roll down the passenger front window from the driver's master window switch as well. The motor in the passenger window is still good as it operates when separate power is provided to it.
Are all of the above problems tied to a faulty master window switch? If I replace the switch will I re-gain the ability to use the passenger window, and the automatic locks?
Is this the appropriate part:?
http://www.amazon.com/Dorman-901-405...ar=1&carId=002
Thanks
terzaghi is offline
post #2 of 9 Old 05-24-2012, 05:53 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
That looks like the right part. A properly functioning master control switch may or may not fix any other issues.
CJ7-Tim is offline
post #3 of 9 Old 05-24-2012, 06:14 PM
obfdcherokee
Check your door harnesses my windows and locks where part time had bad wiring in both doors. Look where the harness comes out of the door and into the body.
obfdcherokee is offline
post #4 of 9 Old 05-24-2012, 07:38 PM Thread Starter
terzaghi
Thanks for the tip. Where specifically do I need to look? Inside the door panel?
terzaghi is offline
post #5 of 9 Old 05-24-2012, 08:35 PM
obfdcherokee
The part in the door jam area that has the rubber sheath around it. Easiest way I found was pull the harness out of the door ( pull the rubber grommets out of the door and body. There's three connectors on the kick panel then the rest in the door. Easy if you have basic mechanical skills) un wrap the harness fix what's broken and but it back in. Or find new harnesses.
post #6 of 9 Old 05-24-2012, 08:59 PM Thread Starter
terzaghi
I will look at the wiring and see if anything looks suspicious.
As far as the master control switch, once the door panel is off is it simple to unhook the old one and hook up the new one?
Thanks again!
terzaghi is offline
post #7 of 9 Old 05-24-2012, 09:28 PM
obfdcherokee
Thanks again!
Yes it has two connectors and either clips or screws that hold the switch in. Beware dont pull the panel off too hard you have to unhook the latch rods before you completely remove the panel
post #8 of 9 Old 08-09-2012, 09:05 AM
jeepers15
My 99 Grand Cherokee Limited lost power from main driver door control panel to windows, door locks, mirrors. Also alarm light didn't work and dome lights wouldn't go off. Threads said to check wires in rubber boot coming from body to door. I pulled the boot from the door side and pulled it back to view the wires. One was broken. I bought 16 gauge auto wire at home depot. Had to slit the rubber boot with a razor to reach the broken part and give myself working room. Cut about a 3 inch section of new wire and stripped both ends. Stripped both ends of existing broken wire. Used 16 gauge crimp type butt splices (hardware store) and connected the wires back together with the new splice in between the old wires. Turned power on at key and ALL IS FIXED!!! Use electrical tape to close up boot as best you can. I couldn't get mine to reseat in the hole properly, but I made it as waterproof as possible with tape. Total cost about $8...total time around 45 minutes. GOOD LUCK!
jeepers15 is offline
post #9 of 9 Old 09-22-2013, 09:53 AM
hooksup
1999 FSJ Cherokee
Master door switch
I just purchased a 99 Grand Cherokee and my master door switch will only work if my door is closed. What is the problem and what do I need to do to fix it. Also how do I program the key remote, they car came with no remote and I am buying one from Ebay and need to know how to program it.
hooksup is offline
1996 Jeep Cherokee 4WD- Brake Issue. Master Cylinder? Bleed Brakes? Busted Brake Line mjkjr1222 General Jeep & Off-Road Equipment 0 08-06-2011 09:25 AM
1999 XJ Window Lock switch Chace365 Audio, CB & Ham Radios, GPS, & Electrical 0 05-17-2011 08:03 AM
Master Disconnect Switch MikNov Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2009 02:01 PM
98 XJ Door locks AND window switch problems!! Grr Cobrajay Audio, CB & Ham Radios, GPS, & Electrical 0 10-04-2008 08:56 PM
Auto up/down window rocker switch for all 4 windows? ajent420 Street Jeep Forum 10 04-04-2007 09:23 PM
