Interior Light Problem - JeepForum.com
post #1 of 7 Old 10-21-2013, 01:17 AM Thread Starter
maxgee
Today I was trying to install a switch for some lighting in the footwell of my car and in the process I messed up some of my interior lighting. The problem that occurred is that all of my interior lighting besides the two front door lights have stopped working. The dash lights still work, the lights that don't work are the footwell and overhead/dome lights in the whole car. I have a 1999 Grand Cherokee (WJ) it is a V8 Limited also if that helps. I tried looking at the fuse box in slot 7 and the fuse looks fine and I have tried putting a new fuse in and have had the same results.
PLEASE HELP!
maxgee is offline
post #2 of 7 Old 10-21-2013, 12:57 PM
kjg26
kjg26's Avatar
Did you cut any wires during your install? If so, that's where id start
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #3 of 7 Old 10-21-2013, 01:00 PM Thread Starter
maxgee
I didn't cut any that would affect all of the interior lights of the car.
maxgee is offline
post #4 of 7 Old 10-21-2013, 01:05 PM
kjg26
kjg26's Avatar
Just saying that's were I'd start. Maybe cut or knocked free a ground that was common.
kjg26 is offline
post #5 of 7 Old 10-21-2013, 01:05 PM
Psycho-X-Jeep
2009 JK Wrangler
PLEASE HELP!
Did you completely cut ANY wires in the process of installing the switch (Not just wires that are applicable to lighting)? Remove the newly installed wiring, ensure all factory wiring is intact, and see if everything goes back to normal. If so, you did something funky with the installation. If not, you have a bit of a larger issue.
Call me Eddo
09 JKUR
13 WK2 Trailhawk
Psycho-X-Jeep is offline
post #6 of 7 Old 10-21-2013, 01:20 PM Thread Starter
maxgee
I cut one wire off of the power outlet but after the lights stopped working I put it back together and it still did not work.
maxgee is offline
post #7 of 7 Old 10-23-2013, 09:59 PM Thread Starter
maxgee
FIXED THE PROBLEM! I was looking at the wrong fuse it was #8 instead of 7. LIGHTS WORK!!
maxgee is offline
fuse block , interior , lighting , problem , wj
