Interior Light By-Pass Switch Write-Up (PICS)!
#46 | |
looks like you went at it the hard way!
I would just use blade connectors on the end of my wire leads to my switch that I could stick in the fuse box. Mount the fuse inline and you're good to go.
#47 | |
If you pull the fuse the (DING) goes away.
The above post is my opinion and I have no facts to prove it... :)~ http://www.tjhardcore.com The ultimate TJ owners only forum |
#48 | |
I like that Idea. A switch was the first mod I did. One of the best so far. Never had to remove that fuse ant it is so easy. |
#49 | |
My 1 ton TJ build project "Evil Monkey": [url]http://www.jeepforum.com/forum/showthread.php?t=423989[/url] |
#50 | |
Better to use a SPDT Relay - Put Ground for the buzzer on the Normally Closed terminal, and connect the coil to ignition... When the Ignition is on, it'll throw the relay over to the Open terminal - and the buzzer won't sound. Remove the key and the buzzer will sound because it now has a working ground. |
#51 |
I dunno.. seems to me that a Jeep is Built .. NOT Bought!! I still prefer the fuse out and I make sure I turn my headlights off after use!!
just my 2 cents! |
#52 | ||
RESIDENT METAL
**** Inappropriate content removed by moderator ****
I have a Jeep. Quote: Quote:
#53 |
Dear God, can we forgo the never-ending debate on whether this is an acceptable mod or not, and simply accept that some people like the idea of installing a switch instead of pulling a fuse or putting clamps on the door plungers?
That would entail not resurrecting a thread that hasn't been opened for 11 days with a simple opinionated comment. **** Inappropriate content removed by moderator **** Cheers! M2 |
#54 | ||
RESIDENT METAL
and could you not put premade smiley's in your post. only post them if you drew them yourself![]()
#55 |
hey i'm just glad Lupinsea mentioned that bit about chopping the ground wire instead...
made an easy job cake... and i'm a fat guy...
Join these groups... NGJC #4 - VA Jeepers - LJ Owners "I'm not a Republican because I grew up rich, but because I didn't want to spend the rest of my life poor, waiting for the government to rescue me." MH The less a man makes declarative statements, the less apt he is to look foolish in retrospect. - CR Finally, a word to those of you out there who have yet to be offended by something I have written or said: Please be patient. I am working as fast as I can. - AC |
#56 | ||
RESIDENT METAL
#57 |
Isn't it true the warning buzzer doesn't come on when your headlight is left on when you turn off engine and remove the key to exit the Jeep? It does that to me. May be I did it wrong with the fuse box, but I was caught several times with headlight left on for some extended time.
It would be nice to do the switch tech w/o disabling this function.
2009 JK Rubicon. Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip. Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009. Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008. http://community.webshots.com/user/thunder1strike |
#58 | |
Your mom's favorite
The quadratec one is just the blade into fuse panel trick, you can do it for about $10 vs $25, but either option works, if you're comfortable cutting into the short wires, it's a great alternative.
Lack of planning on your part does not constitute an emergency on my part. '88 YJ, 33's, auto, begging to be modded. Can't wait!
#59 |
great write up i did mine tonight took no time at all
,=====o00o //___l__,\____\,___ l_--- \___l---[]lllllll[] _ _(o)_)___(o)_)--o-)_) only in a JEEP |
#60 |
hey glad this write-up is still helping ppl out.
umm... it's just a switch. what's all the fuss about lol. i come back one day and my 8-month-old thread is revived with people rabbling about it. i dunno ~J
Formally JeepinTJ99 ... Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP Will be missed: 1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
