installing subs and amp in a wrangler - JeepForum.com
post #1 of 5 Old 01-16-2009, 04:14 PM Thread Starter
platinumjeep
i just bought some cheap mtx subs and amp to throw in the wrangler. the amp is a 400 watt mono and the subs are 12s i couldnt tell you much else about them, all brand new. anyways, would i be ok mounting the amp under the back seat? would it get enough airflow under there? also, do you have any ideas on how to secure the stuff so that it wont be stolen. i run a soft top and it is off 97% of the time in the summer. i have thought about just mounting the box to the tub with some brackets and big sheet metal screws, but i dont really want to drill into the tub. it could still be stolen, but it would take some time. any body have any other suggestions? thanks
platinumjeep is offline
post #2 of 5 Old 01-16-2009, 04:17 PM
kolten493
i have my amp mounted under the seat and its never shut down on me, and i built a box for my shallow mount 10. you might be able to do something similair. and yes, i used sheet metal screws to secure it
"the guy who decided to use torx bits on jeeps
should be severely beaten"
kolten493 is offline
post #3 of 5 Old 01-16-2009, 07:55 PM
flexsaharatj
i have my 2 10inch JLS in the back where the box fits perfectly, and won't be able to be removed unless the hatch is open
with the rear seat back all the way and the hatch closed, you cannot lift up the subs which is great, and the only way to flip the seat forward on my 97 is to take out the subs to get to the lever...
and my amp for now is just chilling under my rear seat... will get some heavy duty velcro to secure it soon though
flexsaharatj is offline
post #4 of 5 Old 01-16-2009, 08:19 PM
gily25
well there are a bunch of cargo tie downs already bolted into the floor. I think you figure something out with how to use those current holes. Other option if you don't want to drill is weld some bolts to the floor, drill holes in the box and put the nuts inside the box to hold it down.
It depends on the amp but a 400 watt amp should be fine under there and I can't say I hear of a lot of mtx amps overheating (decent brand)
gily25 is offline
post #5 of 5 Old 01-18-2009, 12:01 AM
OneCleanYj
This is exactly my situation and basically what I ended up doing. I got some cheap "L" brackets from a local home improvement store and secured them with some specialty bit screws, figure most crooks won't be carrying the correct tool But I've since taken them off, mainly because my top is on most of the winter and sound resonates through the tub BAD when screwed down. I plan on getting a Dynamat trunk kit for the rear section which I hope will eliminate the resonating sound. Just as you said this set-up can still be stolen, but it will take more time and hopefully a crook will pass on to the next unfortunate victim
Sub amp is under my front seat and the location seems to work fine for me. I don't go through deep water/mud and you'd have to remove the seat to get the amp Remaining amp and a signal processor are well tucked away under the carpet on the front section of my wheel wells. Small equipment rocks
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
installing 3 subs and amp in liberty Mike1127 Audio, CB & Ham Radios, GPS, & Electrical 18 06-16-2010 12:55 PM
Subs for a 03 wrangler Zacb262 Audio, CB & Ham Radios, GPS, & Electrical 33 07-16-2009 12:12 AM
subs for a wrangler DannyMK2 Audio, CB & Ham Radios, GPS, & Electrical 13 12-04-2005 09:26 PM
Where to put SUBS? Wrangler TJ? Bryan_16 Audio, CB & Ham Radios, GPS, & Electrical 15 08-09-2002 04:38 PM
Subs in a 98 wrangler? 98sporttj Audio, CB & Ham Radios, GPS, & Electrical 1 06-04-2002 01:19 PM
