installing factoy fog lights - JeepForum.com
post #1 of 5 Old 11-17-2010, 08:24 PM Thread Starter
jjnb
i have 06 wrangler x and just purchased mopar factory fog light kit 82208017. my jeep has factory wiring for fog lights, can i just install the new turn signal switch, fog light, and put in a relay in the relay compartment to make them work.
jjnb is offline
post #2 of 5 Old 11-18-2010, 12:16 AM
PlatinumNiner
That should be all you have to do yes.
PlatinumNiner is offline
post #3 of 5 Old 11-18-2010, 08:22 AM
private
What would be entailed for a 98 TJ with no factory wiring for them?
1998 TJ 2.5 5spd
private is offline
post #4 of 5 Old 11-18-2010, 08:41 AM
PlatinumNiner
Mount the switch and run the wires. TJ's are VERY easy to run wires in.
post #5 of 5 Old 12-10-2010, 04:35 AM
hesterj
I found on my 05 TJ that part of the harness was missing right off the bat. I just went ahead and ran the supplied wire harness in the kit. It really only took a extra few minutes and the overall results looked good.
I also found out the hard way when installing the kit that the color code was wrong in the instructions.go by the placement of the pins in the instrument cluster connectors instead of what the color should be. It will keep you from going crazy.
hesterj is offline
Installing aftermarket reverse lights? taylorC Audio, CB & Ham Radios, GPS, & Electrical 7 01-27-2010 06:57 PM
Need help installing aux lights! Prokop5588 Audio, CB & Ham Radios, GPS, & Electrical 2 06-28-2008 12:02 PM
Trouble Installing Fog Lights RWB214 Audio, CB & Ham Radios, GPS, & Electrical 6 10-24-2006 01:25 PM
DOH! installing driving lights.. evilpsych General Jeep & Off-Road Equipment 3 11-18-2001 03:14 PM
Installing front fog lights - help! tangodancer General Jeep & Off-Road Equipment 6 04-02-2001 03:15 AM
