Install ligjt bar. Please help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Install ligjt bar. Please help
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 04-05-2014, 08:14 AM   #1
SRC87
Hey guys, I will be installing a 10' ridge industries LED light bar. I have never installed one before. Do you just have a switch mounted inside or can they be wired into my wiring harness for my fog lights. Btw the bar is being mounted on an after market bumper and I will not be using the OEM fog lights. Any suggestions?
SRC87 is offline   Reply With Quote
Unread 04-05-2014, 08:20 AM   #2
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
1. A 10 foot bar will not fit. Not even sure if they exist.
2. What vehichle do you have?
3. Fill out your profile information.
Install is pretty straight forward. They can be wired up any combination of ways.
Direct off the battery to a switch
spliced into the harness to run with the parking lights, low beams, or high beams
spliced into the harness to run with aforementioned lights but also switched to turn on or off as more or less light is desired but only when the other lights are already on.
Do you have factory fogs??? If you're not using them splice in there and you're good to go. Although the bar won't work with the high beams on.
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
Build Thread: Operation Funsized
TJ_Tim is offline   Reply With Quote
Unread 04-05-2014, 08:24 AM   #3
88YJRay
If you are not going to use the OEM fog lights just take them off and splice your bar into the factory fog light harness. Then it 'a already fused and you have the factory switch. Simple as that.
Ray
88YJRay is offline   Reply With Quote
Unread 04-05-2014, 08:26 AM   #4
88YJRay
Oh,I know what you meant on the bar but I have to say this anyway. 10' bar would be pretty awesome but may be a little wide for the trails. Lol
Ray
Unread 04-05-2014, 08:41 AM   #5
SRC87
Sorry lol yes a 10 inch bar
Unread 04-05-2014, 08:48 AM   #6
SRC87
Thank guys for the advice. I'll have to look up how to splice them into the factory fog lights. I have never done anything like that. Thank again.
Unread 04-05-2014, 08:49 AM   #7
88YJRay
Get a test light turn on the switch. Touch the test light to the wire, should only be two wires, and when it lights up that the power wire, simple as that!
Ray
Unread 04-05-2014, 08:56 AM   #8
TJ_Tim
TJ_Tim's Avatar
Assuming this is a TJ, yes it's a piece of cake.
Unread 04-05-2014, 09:04 AM   #9
SRC87
Unread 04-05-2014, 09:05 AM   #10
SRC87
I have a 2013 jeep wrangler
Unread 04-05-2014, 09:06 AM   #11
SRC87
Thanks Ray for the help! Didn't realize it was that simple
Unread 04-05-2014, 09:09 AM   #12
TJ_Tim
TJ_Tim's Avatar
On the new JKs the lights are controlled by the computer. If the loads for the lights differ from stock they may not work.
Unread 04-05-2014, 09:32 AM   #13
88YJRay
Did not know that TJ, I'm old school don't like all that computer controlled crap! Lol. Still it's worth it to try though.
Ray
Unread 04-06-2014, 10:01 AM   #14
88YJRay
I just went back and read this and you need to keep in mind what was said here about the lightbar not working with the high beams on.
Ray
Unread 04-06-2014, 11:35 AM   #15
TJ_Tim
TJ_Tim's Avatar
Since I said this and then cleared up the matter in a later post it stands.
IF the OP would have addressed 2. and 3. prior to posting his question the issue would've been resolved faster.
