Install an Amp Under the Dash for fifty cents -Lots of pics - Page 4 - JeepForum.com
post #46 of 84 Old 01-28-2013, 08:50 PM
mrpistol
thanks to this thread for the amp idea. The rockford fosgate amp I used can technically be mounted inverted (in a trunk), according to the manual. I would imagine the space under the steering column is about the same.
http://www.phillipyu.com/jeepsub
mrpistol is offline
post #47 of 84 Old 03-05-2013, 07:38 AM
jlrenken
any updates on how the amps have holding up to being mounted upside down. I just orded an exlpde mono and I was planning on doing this but if they have held up then undder the seat will do.
jlrenken is offline
post #48 of 84 Old 03-05-2013, 01:36 PM
freeskier93
Mine has been fine for the past year.
freeskier93 is offline
post #49 of 84 Old 03-05-2013, 02:42 PM
jlrenken
how hard have you been working it. Im going to pushing a pioneer 12 shallow with rms 400ws
jlrenken is offline
post #50 of 84 Old 03-05-2013, 04:23 PM
jlrenken
what are your setting your running. Im pretty new to this and was wondering a good place to start.
jlrenken is offline
post #51 of 84 Old 03-11-2013, 05:22 PM
hlbridner
1991 XJ Cherokee
is there any way to run power to my amp without drilling holes thru my firewall
hlbridner is offline
post #52 of 84 Old 03-12-2013, 05:54 AM
mike_dippert
mike_dippert's Avatar
There may be an existing hole you can use. It'll have a rubber plug in it.'
mike_dippert is offline
post #53 of 84 Old 03-12-2013, 12:11 PM
bluewatertj
Look up and to the left from the brake pedal. There should be a rubber grommet that some other wires are passing through. You can use a screw driver to poke a hole in there relatively easily.
bluewatertj is offline
post #54 of 84 Old 03-18-2013, 04:13 PM
hlbridner
1991 XJ Cherokee
1
post #55 of 84 Old 03-18-2013, 04:34 PM
MyKeyB
Umm...
Did I miss something?
MyKeyB is offline
post #56 of 84 Old 04-21-2013, 07:10 PM
boab
Wanted to thank the OP for this idea, I just did mine and its an awesome spot for an amp. I have a Rockford fosgate pbr300x1 there, and replaced the stock radio with a nexus 7, that allows a pbr300x4 to fit behind there. Sounds awesome
boab is offline
post #57 of 84 Old 04-22-2013, 07:50 PM
supbuckeye
Yep I installed both my PBR300x4 & 300x1 up under the dash. But hoy was it hard getting that bolt in under the steering column!
supbuckeye is offline
post #58 of 84 Old 04-25-2013, 09:02 PM
Trendsetter75
2010 JK Wrangler
To the OP what is the max size amp I can fit in there. I was looking at getting the Alpine MRX-F65
The size is •Dimensions: 10-5/8"W x 9"D x 2-1/4"H
2010 JKU (6-spd)
Trendsetter75 is offline
post #59 of 84 Old 05-08-2013, 03:54 PM
storminone
I had looked at putting my MRV-F300 up in the dash but it looked tight so I took out the factory sub box and mounted inside the console. It's driving 4 Polks and sub box in instatrunk.
storminone is offline
post #60 of 84 Old 07-03-2013, 09:59 PM
NalinMFG
how's the durability 2 years later?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
pics of painted dash??? anyone ever paint there dash? xj5399 Street Jeep Forum 21 02-20-2013 09:04 PM
YJ to TJ grill with lots of pics kevin_tall_jeep Fabrication Shop 12 01-12-2013 11:13 PM
problems during front speaker install (also, in-dash amp pics inside) Peregrine777 Audio, CB & Ham Radios, GPS, & Electrical 0 02-14-2010 06:29 PM
Making room for IROKS: lots of pics KY TJ Fabrication Shop 74 03-04-2009 01:38 PM
Custom CB install in Overhead console on '01 XJ WARNING lots of pics!!!! Atl-atl Audio, CB & Ham Radios, GPS, & Electrical 6 12-22-2007 07:41 PM
