> General Technical Discussions
> Electrical, Audio, GPS, & 2-Way Radio
Install an Amp Under the Dash for fifty cents -Lots of pics
12-01-2011, 02:03 PM
#31
Originally Posted by julietkilo
good to know for others on here, you may have to drill a hole or use 90 degree angle brackets on the steering column bolts.
I think a 90 degree bracket will have to go. There's not really anywhere to drill a hole at.
02-07-2012, 06:34 PM
#32
sorry for not seeing this, just looked back at older threads. Did you get that bracket to work? Do you have pics for the people of the different years that my mount may not work on?
[SIZE="1"][COLOR="Red"][B]2003 Flame Red Rubicon [/B][/COLOR][URL="http://www.jeepforum.com/forum/f22/rubired-armored-lcog-tumtukd-daily-driven-pictorial-1285548/"]RubiRed Build Thread[/URL]
tummytukd on 35's
Air Force Loadmaster/Air Force Jeep Club [B]#12[/B]
[B][URL="http://www.jeepforum.com/forum/f7/i-am-petersens-4wheel-off-road-magazine-pics-526488/"]Me in Petersons 4-Wheel Off-Road Magazine[/URL]
[/B][/SIZE]
02-07-2012, 08:42 PM
#33
Nope, sorry. I havent tried to mount the amp. But I can take a pic of the steering column where the hole should be but isn't if thats what you're asking?
02-07-2012, 09:25 PM
#34
no biggie just wondering.
tummytukd on 35's
[/B][/SIZE]
02-07-2012, 11:02 PM
#35
Hey thanks for the writeup! I used this to mount my amp last weekend. It is a pioneer GM-D7500M Class-D, which looks to be a similar size to your sony. I used leftover MDF from the Sirgcal in-seat box I used for my sub to make the bracket. The sub is a shallow mount Pioneer and sounds great!
The bracket on my steering column also does not have that hole, which would have been convenient. I used some washers and a couple long bolts to bolt it to some u-shaped parts of the steering column bracket, which look somewhat similar to what you can see in the pictures in your writeup. I am away from my jeep for the next few days, but will post some pics when I can. Hopefully it will help for others with earlier TJ's.
02-07-2012, 11:19 PM
#36
cool, cant wait to see the pics.
tummytukd on 35's
[/B][/SIZE]
03-31-2012, 07:30 PM
#37
So I had my dash apart today and remembered I said I'd take some pics of the older years setup. In the first one, you could drill a hole where the white dot is and make an angle bracket. Or What I think Kylo did (black lines as bolts). First time I looked at it the idea I came up with was an angle bracket on the steering column mounting studs.
08-11-2012, 12:50 PM
#38
For future reference.
10-10-2012, 09:18 AM
#39
Mounting an amp upside down is the absolute worst thing you can do.
Heat rises. The heat sinks on an amp are along the side and the entire top side of the unit.
When mounted upside down, you take the entire top side of the heat sink out of play because the heat will go the other way.
Eventually you will fry the amp by overheating it.
2000 Jeep TJ Wrangler - 4.0L, 5 speed standard - BONE STOCK FOR NOW
10-10-2012, 09:56 AM
#40
"Generation Dead"
This is a generalized statement not true for all amps. There are a number of amps designed to be mounted upside down.
My amp for example has a built in cooling fan. It has been mounted upside down in this position for a year and still runs flawlessly.
10-10-2012, 10:30 AM
#41
Yes, you are correct as I should have mentioned - unless stated in the user manual.
However, this statement is true for more than the majority of amps.
And there is not one amp pictured in this entire thread that is designed to be installed upside down.
10-10-2012, 10:38 AM
#42
"Generation Dead"
How so, because the picture of MY amp in post 11 is certainly can be installed upside down.
10-10-2012, 07:43 PM
#43
Fan cooled is a good choice for inverted or tight space installs.
Alpine PDX Amps are a great high end easy choice for inverted installs. Also soundstream stealth series, the JL, the kicker, and any of the other micro amps bc they don't use traditional heat sinks.
iPhone app user; excuse typos...thanx.
11-28-2012, 03:02 PM
#44
Impressive
12-30-2012, 04:23 PM
#45
Did this install last week with Sony XM-1S.
Thanks for the info dude. Install went great. Hooked up the Sony XM-1S to a Kicker 6.5" CVT in the stock location. It sounds great.
Next stop is possibly putting the SSV Works 10" enclosure in place of the stock one so I can get some real low end.
