Install of amp and tuffy speaker console - JeepForum.com
post #1 of 6 Old 05-06-2005, 10:14 AM Thread Starter
Molotov
I just ordered a new Tuffy console(full speaker #0066) to replace my crappy half one that came stock on my 04 TJ. Once it arrives i'm going to install it a sub and amp. I installed my current head unit and speakers myself but have never done an amp/sub before.
Are there any pitfalls i should know to avoid? I found a nice little walkthru of installing a similar Tuffy console on nakedjeep.com.
Whats the ideal spot for an amp on an 04 TJ?
Any help is greatly appreciated.
Molotov is offline
post #2 of 6 Old 05-06-2005, 10:21 AM
SirGCal
SirGCal's Avatar
Well, it depends, are you using a stock sub/amp or going to go aftermarket? If your going aftermarket on the tuffy console, you'll have to build a custom box to house the sub which fits inside the tuffy and doesn't block the e-brake. You could fit an 8" in there pretty easily. Then you need a place for the amp to power it. (with the sub in there, it's doubtful you'd get an aftermarket amp to fit short of the xtant 1.1.)
Installing them is farily strait forward, you need adequite power wire for the amp, a fuse, ground wire, RCA wires (or speaker level inputs on the amp or a PAC line-level converter) speaker wire (16-12 AWG for subs normally, depending on their power) and a remote signal wire (18-16 AWG is more than enough...).
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 6 Old 05-06-2005, 10:31 AM Thread Starter
Molotov
Make my own box, Doh! I've never done that, anyone have specs for that.
Thanks for the quick reply.
Molotov is offline
post #4 of 6 Old 05-06-2005, 10:36 AM
SirGCal
SirGCal's Avatar
Doug on webshots has a small write up. No clear cut plans but he did put the measurements on there. I havn't saved any of my designs for public use yet but the next one I do I will.
Doug's stuff: http://community.webshots.com/album/63423573sSraTy
SirGCal is offline
post #5 of 6 Old 05-06-2005, 10:41 AM Thread Starter
Molotov
Good link, some of the pics have measurements which will be a nice guideline(i'll do my own for exactness).
So assuming i get the sub box made and setup, is there a spot for the amp that you would recommend, i haven't bought the sub or amp, so i'm open to suggestions anyone has.
On a side note i checked out your site SirGCal and that sub in the rear seat is damn nice. If i had more confidence in my skills i would love to give that a try.
Molotov is offline
post #6 of 6 Old 05-06-2005, 11:03 AM
SirGCal
SirGCal's Avatar
If your putting the sub in the center console, then under the rear seat is an option for the amp the one thing about that location is you don't have to worry as much on amp physical sizes. Other locations include under the dash (hard) and driver's seat or inside an insta-trunk.
SirGCal is offline
Tuffy Center Console w/speaker?? bronze493 Audio, CB & Ham Radios, GPS, & Electrical 2 12-04-2006 11:30 AM
help with stereo in Tuffy console install Johnny World Audio, CB & Ham Radios, GPS, & Electrical 4 04-03-2006 01:36 PM
Tuffy stereo console/speaker questions Roadkill43 Audio, CB & Ham Radios, GPS, & Electrical 5 05-29-2005 08:00 PM
Tuffy stereo console + system install ?'s wyldejackyl Audio, CB & Ham Radios, GPS, & Electrical 22 02-27-2005 09:02 PM
Tuffy console install question Shinner Audio, CB & Ham Radios, GPS, & Electrical 3 10-07-2003 01:07 AM
