Inseat sub box question - JeepForum.com
post #1 of 12 Old 08-22-2006, 10:20 AM Thread Starter
blorge
This may best be answered by SirG, but will throw it out to all. I am thinking about building the rear in seat sub box, and was wanting to buy either an 8" or 10" kicker solobaric sub. they are rated at 400 watts RMS, so I have a few questions.
1. Will the sub work, I beleive that the 8" is 4 11/16 inches deep?
2. What is a good wattage amp to go with to push the speaker, and what brand of amplifier do you recommend?
I was thinking off mounting the speaker off to one side and then mounting the amp next to the sub, possibly even recessing it for a cleaner look.
Blorge - 99 Blue TJ
6" FabTech Lift on 37" IROKS
CJ tailgate Conversion
blorge is offline
post #2 of 12 Old 08-22-2006, 11:43 AM
SirGCal
RIP
SirGCal's Avatar
For the S8L5 (4.75" mounting depth), you could run one of em. Actually you could run two of em but it will be tight. Minimum volume for one of those 8" squares are .33 ft^3, the large in-seat box has .87 ft^3 (not including volume consumed by the sub itself) so it's going to be tight but it should work. I would also add a full amount of polyfill to the box too though cause those subs like more around .5ft^3 each...
Now, assuming you want to run two S8L5's (as I figure you're thinking of doing), you would want to get the 2-ohms (per coil) version to make getting the amp cheaper. Then you would wire them up to show the amp a total of 2-ohms using a method similar to this: [/url]http://www.sirgcal.com/images/dvc.jpg[/url]
Then you need an amp that puts out up to 600Wx1 @ 2-ohms. (400W+ would work great...) Maybe: Alpine MRP-M450 (400W), Alpine MRP-M650 (600W), Alpine MRD-M605 (600W), Kicker ZX400.1 (400W), MTX Thunder TC 4001 (400W), Polk MOMO C500.1 (500W), Audiobahn A12005DN (600W), Rockford Fosgate Punch P6001BD (600W) to name a few...
To run the 4-ohm subs instead, you might also save by finding a 2-channel amp and bridging it to 4-ohms (like the above url). Amps that would work good with a pair of 4-ohm L5 8" subs: Profile HA1000 (480W), Profile AP1000 (480W), Profile AP1200 (600W), Sony XM-2002GTR (500W), Kenwood KAC-7252 (500W) to name a few...
If you're wanting to run just one, then you need an amp that does 150-300W RMS at 2 or 4-ohms. If the amp does that at 2-ohms, get the 4-ohm sub and wire them in parallel. If the amp does it at 4-ohms, get the 2-ohm sub and wire it in series.
A good example might be the Profile AP600 (300Wx1 @ 4-ohms). Wire that up to a 2-ohm S8L5 wired coils in series (like one of the subs in the above diagram) to show the amp a 4-ohm total impedance. Or a Rockford Fosgate Punch P3001 (300Wx1 @ 2-ohms) wired to a 4-ohm S8L5 with the coils in parallel (each coil to the same amp's outputs directly is the easiest to explain it).
WORD OF CAUTION THOUGH! If you plan to run the L5's in the seat, you may need additional bracing to keep the box from resonating. That's a lot of power for 5/8" material. Upgrading to 3/4" would be nice but you would lose internal volume you need for them. So it's a catch 22... I would go bracing in this situation. Add plenty and rubberize the inside. Should be ok.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 12 Old 08-22-2006, 12:12 PM Thread Starter
blorge
WOW, thanks for the great info!!!!
I am gonna run just one dual voice coil 4 ohm S8L7, so I will need a 400 watt amp. I partition the box off to make it .5 cubic feet and add to the structural integrity.
Blorge - 99 Blue TJ
blorge is offline
post #4 of 12 Old 08-22-2006, 12:49 PM Thread Starter
blorge
Ok, so I just purchased the
Alpine MRP-M450 and the S8L7 4 ohm 8 inch speaker.
total $250.00 not too bad!!! will post pictures when i am done...
Blorge - 99 Blue TJ
blorge is offline
post #5 of 12 Old 08-22-2006, 01:21 PM
C2U5H
C2U5H's Avatar
good luck blorge!
measure 10x, cut once, especially on chris' design.
takes some pics a long the way to keep the electrical section lurker's happy!
~J
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #6 of 12 Old 08-23-2006, 02:42 PM
Torn66
Definetly keep us posted. My brother has solobariks and they are amazing..Im building my box now and havent decided on amp/sub(s) yet...would love to jear opinions
06 Rubicon
2in BB__1in BL__32 BFG Muds__SIRGCAL in seat box
Torn66 is offline
post #7 of 12 Old 08-27-2006, 06:43 AM Thread Starter
blorge
I started the box over the weekend. Should be done by the end of the week. the little solo baric 8" looks pretty inpressive pulling it from the box that it was sent in... I cant wait!!!!
Blorge - 99 Blue TJ
blorge is offline
post #8 of 12 Old 08-30-2006, 09:39 AM
msavard
msavard's Avatar
Please track this install with instructions and photographs. I'm very interested in doing the same install and would love to follow in your footsteps.
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto 35" Maxxis Bighorns D30/D44 w 4.88 Gears 2.5" OME LJ/XJ lift JKS Trackbars Brown Dog MML 1" BL Warn Engine Skid Aussie Locker (FR) / Rubi Air Locker (REAR) SYE/CV Nth Adj Control Arms Bestop Oversize Tire Carrier PSC Rocker Knockers ORO Swayloc TNT Tube Fenders
msavard is offline
post #9 of 12 Old 09-02-2006, 12:35 PM Thread Starter
blorge
Well after some tough box building, I have the box installed. I must say that now my rear seat feels much higher than before. Hope no one hits there heat on the roof!! I didnt get any photos of the building of the box, but sirG has plenty of great photos on his website www.sirgcal.com. I will try to get a photo of the finished product.
Blorge - 99 Blue TJ
blorge is offline
post #10 of 12 Old 09-02-2006, 08:48 PM
slowTJ88
Blorge/SirG/anyone else,
I am planning on doing this in the near future. One thing that I have not seen anything about and been curious about is speaker terminals. I plan on using a single 10". Where would you recommend putting the terminal?
Thanks.
1985 CJ7 Laredo
258, T176, D300
31x10.50s
slowTJ88 is offline
post #11 of 12 Old 09-03-2006, 06:44 AM Thread Starter
blorge
I put the terminal on the side of the box, and just fished the wire to a hole in the seat fabric by the bottom front corner so there is no binding on the wire when the seat is moved up and down.
Blorge - 99 Blue TJ
blorge is offline
post #12 of 12 Old 09-04-2006, 02:51 AM
SirGCal
RIP
SirGCal's Avatar
I didn't put terminals in the box. Simply using a wood-pinching method for holding the wire through the box without leaks (hard to explain. but small piece of wood with a channel chissled out, pinching the wire at a 90deg angle when it exits through a hole in the box, stuffed with silicone also.) followed by deans connectors. I did it at the front side of the box in the space for the seat hardware.
SirGCal is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 Engines & Drivetrain 0 10-21-2009 11:13 PM
SirGCal inseat sub box -- complete *lots of pics* samger2 Audio, CB & Ham Radios, GPS, & Electrical 17 04-01-2007 08:59 AM
Daul 10" Inseat Sub Box With Lots Of Pics! nitwit527 Audio, CB & Ham Radios, GPS, & Electrical 11 02-24-2007 09:13 PM
SirGCal - InSeat Speaker box Question. Bhelliom Audio, CB & Ham Radios, GPS, & Electrical 2 07-26-2006 12:42 PM
My 2" BB lift question - in depth, and HUGE question WheelinTJ2004 Tires & Wheels 11 02-01-2005 07:17 AM
