I'm getting a new PCM installed and have a quick question. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & HAM Radios, GPS, & Electrical. > I'm getting a new PCM installed and have a quick question.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 12-01-2013, 09:16 PM   #1
Bluebell
2003 KJ Liberty
A local dealership will be installing a new PCM in a few days. I'm curious, once it's installed, about how many miles does my KJ have to be driven in order for the PCM to run through all the engine checks it normally does?
I have 2003 Jeep Liberty Limited with a 3.7L gas engine.
Thanks.
Bluebell is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 03:25 PM   #2
Bluebell
2003 KJ Liberty
nobody???
Unread 12-02-2013, 03:56 PM   #3
222Doc
222Doc's Avatar
not sure what you are getting at. when you turn the key it goes through it. when its running its checking. The mapping of how you drive will take many key cycles. but if you ever disconnect the battery long enough that can reset that anyway. nothing to worry about.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 09:57 PM   #4
streetglideok
2005 KJ Liberty
If you are talking about the OBDII monitors, that depends on driving style, etc. Can be as little as 10 miles, to as many as a few hundred miles. As little as a single day, to as long as several weeks. I always cringe when I read about replacing a pcm. Too many are replaced out of desperation, and it doesn't fix anything.
streetglideok is offline   Reply With Quote Quick reply to this message
