ignition timing any tricks for inline 6 1996? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > ignition timing any tricks for inline 6 1996?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 07-24-2012, 10:38 PM   #1
jamiejojo
Anyone know if there are any hidden tricks or secrets on setting the ignition timing for a inline 6 1996 grand cherokee? For instance do I have to unplug anything or re-set anything? Thanks.
jamiejojo is offline   Reply With Quote
Unread 07-25-2012, 07:03 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
IGNITION TIMING
NOTE: Base (initial) ignition timing is NOT adjustable on any 4.0L/5.2L engine. Do not attempt to
adjust ignition timing by rotating the distributor. NOTE: On 4.0L 6–cylinder engines, do not attempt
to modify the slotted fork on the distributor housing to get distributor rotation. Distributor position will
have no effect on ignition timing.
All ignition timing functions are controlled by the powertrain control module (PCM). For additional information, refer to the appropriate Powertrain Diagnostics Procedures service manual.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
1996 , timing
