ignition switch problems - JeepForum.com
post #1 of 4 Old 09-09-2004, 01:34 PM Thread Starter
Budlight
Budlight's Avatar
my ignition is fine, jeep cranks every time, but sometimes when i crank up the power to my radio, wipers, and turn signals cuts off....i can wiggle the key and switch a lil' bit while it is running and most of the time everything powers back up..has anyone else experienced this problem.....do i need a new ignition switch or is it just something loose inside the steering column......??
2000 Solar Yellow TJ, 4" Skyjacker susp., 15" x10" American Racing 23, 33" Procomp mudders, Rugged Ridge Rock front bumper, Barnes 4wd rear bumper,
Budlight is offline
post #2 of 4 Old 09-09-2004, 02:04 PM
SirGCal
RIP
SirGCal's Avatar
Sounds like you might have a bad switch and/or loose floating ground somewhere... The only way to know for sure is run a battery of tests... I'd first focus on the switch though. It's one of the easier things to find anyhow... Just see if you can force it to lose connection. (this would happen reguardless of the load).
Other things that might be occuring is you're over-loading the circuit for those options. But I would think the fuse would go instead of everything shutting off... But I assume you haven't replaced fuses with larger ones... (that would be bad...) If you did do this for some reason, then the problem likely tracks back to when you put something else in which overloaded that setup.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 4 Old 09-09-2004, 04:00 PM Thread Starter
Budlight
Budlight's Avatar
ok.. i will start looking at my switch when i get a chance and go from there....stay tuned......
Budlight is offline
post #4 of 4 Old 02-25-2009, 06:03 AM
Hallee
I'm having the same problem. Let us know what you find.
Hallee is offline
Replace Ignition Switch 97 TJ 44 NSB Audio, CB & Ham Radios, GPS, & Electrical 2 02-26-2013 12:11 AM
problems with ignition jkl9964 Engines & Drivetrain 2 10-12-2009 11:30 AM
ignition switch and more shinigami Audio, CB & Ham Radios, GPS, & Electrical 4 12-28-2006 04:04 PM
cherokee ignition switch wiring jeepinor Audio, CB & Ham Radios, GPS, & Electrical 1 04-21-2006 01:58 PM
Ignition switch rootster Audio, CB & Ham Radios, GPS, & Electrical 1 10-18-2005 11:41 AM
