ignition hell, no key cylinder..need ignition wiring help - JeepForum.com
post #1 of 1 Old 01-12-2012, 11:29 AM Thread Starter
Keepajeep
Doing a 4.0L swap and trying to identify wiring from ignition switch on top of column. I located what I believe to be the ignition switch, on top of the column behind the speed/tach. Into this switch go two connectors; one black (4 wire) and one blue (3 wire).
black connector =
RED ( heavy gauge ) constant power 12V
white/black stripe (x2) wires look identical
black/orange stripe
Blue connector=
violet
yellow
black/white stripe
the problem is the key-cylinder is missing from the column, PO had pulled it to replace it and never finished. I thought I could use the pin selector to engage on-ignition-start. No luck, pin behind cylinder for key just spins
I do have an ignition/start panel from 12Vguy. I want to bypass the ignition/key all together.
The motor is freshly rebuilt, hasn't even been started.
I am trying to wire things so I can first ensure I have fuel to the rail.
I want fuel to rail, and haven't got the pump to turn on. I just don't know where to tie in the live feed I have so that my accesories come on.
then prime oil pump manually
ensure spark,
try for initial start up
Keepajeep is offline
Ignition Wiring & Bypass deebjeep Audio, CB & Ham Radios, GPS, & Electrical 4 08-18-2007 02:41 PM
cherokee ignition switch wiring jeepinor Audio, CB & Ham Radios, GPS, & Electrical 1 04-21-2006 01:58 PM
Ignition lock cylinder question.. cj7guy Audio, CB & Ham Radios, GPS, & Electrical 1 12-14-2005 06:48 PM
I need an ignition wiring diagram for a 2000 TJ. Jiraiya Audio, CB & Ham Radios, GPS, & Electrical 0 09-11-2005 02:34 PM
Ignition Module wiring Jami Engines & Drivetrain 2 05-16-2002 04:08 AM
