I want a big, clunky, ugly aftermarket head unit. - JeepForum.com
post #1 of 25 Old 03-01-2012, 08:03 AM Thread Starter
Camio
I want a new head unit. The knob in my 98 TJ's stock unit only works half the time, and I also really want an aux in. So it's time to find an aftermarket unit. However, I HATE every head unit I've found. They all have tiny buttons, obnoxious and bright displays, and are so complicated that I can't figure out how to change the station without fighting with it for 5 minutes. They are all apparently designed for people with Barbie doll-sized fingers who don't mind looking down from the road for a solid minute to change the station, and who never ever drive over a bump. Oh, and they're also designed for people who can get away with a flashy head unit, because their cars actually lock.
Now, what I want is a huge head unit that's actually easy to use and not flashy. I want it to have big clunky buttons that I can find without looking away from the road and a simple display and an aux in. That's all I want. Are there any head units made for people like me, who want the quality of aftermarket, without all the BS on most aftermarket units? Or maybe there's even an OEM unit out of a different vehicle that is relatively cheap and good quality? Please help!
1998 Emerald Green TJ Wrangler
Rockin' the Four-Banger!
Camio is offline
post #2 of 25 Old 03-01-2012, 12:23 PM
Xpress
Put another stock head unit in. Nobody wants that massive POS, so it will never get stolen. Infact, there's probably 10 of them on eBay right now.
If you want a better head unit then you are going to have to get used to pushing buttons. Once you're acquainted with a HU, it's not hard to change stations or songs while driving. Plus, if you took the time to read the manual then you could understand how the entire unti works
All about that unibody life.
Xpress is offline
post #3 of 25 Old 03-01-2012, 12:35 PM
SnowdogMarc
X2 and just about every aftermarket HU has something called a "Detachable faceplate" so you can remove it when you park your Jeep and render the stereo almost useless to a thief
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #4 of 25 Old 03-01-2012, 01:27 PM
gily25
Try looking a the DVD in dash players. Most still play CDs or have aux in but not much for a screen readout. You could look at nakamichi but for the $ id just learn to deal lol. Edit: I see one at woofersetc.com for $160.
I feel ya tho...my alpine has a search button that when hit freezes everything to search. I've accidentally hit that button so many times trying to mute or just turn the volume down. Frustrating!
iPhone app user; excuse typos...thanx.
gily25 is offline
post #5 of 25 Old 03-01-2012, 02:26 PM
Oclvframe
I have two stock head units...both are RBK single cd units. One is an 03 and the other a 05...I'll sell them cheap....LMK.
-r
Oclvframe is offline
post #6 of 25 Old 03-02-2012, 09:38 AM Thread Starter
Camio
Thanks for the tips. Not interested in a stock unit unless it has an aux in though. I have 2 extra stock units sitting in the garage, don't need another unless it has aux in.
Camio is offline
post #7 of 25 Old 03-02-2012, 09:45 AM
MosesYJ
1987 YJ Wrangler
this one isnt to flashy and has some beefy sized buttons not priced to bad either there are tons to choose from on this site
http://www.sonicelectronix.com/item_...oss-822UA.html
Lifted Locked V8 swapped
MosesYJ is offline
post #8 of 25 Old 03-02-2012, 12:10 PM
dmchenry35
Pioneer FTW! http://amzn.to/zjWt5L
'04 Khaki Wrangler X
2" BDS Lift | Adjustable Rear Track Bar | K&N FIPK | 31x10.5R15 on Rock Crawler Series
dmchenry35 is offline
post #9 of 25 Old 03-02-2012, 01:01 PM
driggity
Check out the Jensen Heavy Duty line of head units. I'm considering them because I dislike other head units for many of the same reasons you do.
driggity is offline
post #10 of 25 Old 03-02-2012, 04:50 PM
gily25
I ran a Jensen in my yj...surprisingly for its $ it was a good solid unit.
gily25 is offline
post #11 of 25 Old 03-02-2012, 05:14 PM
theglide
Originally Posted by dmchenry35 View Post
according to your own links, neither of these units will fit a 98 TJ
I recently put one of these in, love the Bluetooth feature and if you don't like the buttons on the faceplate you can always use the remote
theglide is offline
post #12 of 25 Old 03-02-2012, 07:54 PM
Xpress
^No aftermarket radio is a direct fit into ANY vehicle. You always have to buy an adapter or use a special sleeve to get it to fit in.
DIRECT fit as in just pop it in and it magically works, like a seatbelt is a direct fit into its clip.
Xpress is offline
post #13 of 25 Old 03-02-2012, 08:49 PM
theglide
that's true but those radios do appear to be too tall to fit within the space that the factory radio occupies ... so you may need more than an adapter, like a Sawzall
theglide is offline
post #14 of 25 Old 03-02-2012, 09:53 PM
Xpress
Or using a different trim piece. Since TJ's are rather popular, someone out there has one.
Xpress is offline
post #15 of 25 Old 03-02-2012, 09:58 PM
ssquier92
To my knowledge you cant run double DIN in tj.. 1.5DIN would be max... so yes sawzall would be in order unless your getting custom bezel, moving ac knobs down or trimming ac vents up.. Sounds like a bit too much work for double din.
2002 TJ 3.25" RC lift, 1.25 BL, MML, 33X12.50 Goodyear MTR w/ Kevlar, adjustable front trac bar, cut stock bumper, poison hood louver, B&M short shifter, chromoly rear axle shafts in the d44 4.88s Grizzly locker, Aussie locker up front in d30,10,500lb winch w/ synthetic rope, antirock, jcr sliders, savvy arms
Work harder, thousands of people on welfare are counting on you.
ssquier92 is offline
dimming aftermarket head unit secretspy711 Audio, CB & Ham Radios, GPS, & Electrical 0 10-24-2011 08:56 AM
going from stock head unit to aftermarket... which one? greta Audio, CB & Ham Radios, GPS, & Electrical 4 05-20-2010 09:26 AM
Anyone have an aftermarket Head unit AND a Sentry Key- ?? Torn66 Audio, CB & Ham Radios, GPS, & Electrical 24 07-17-2007 06:46 PM
Go with aftermarket, or stay with OEM head unit? RipcordAFF Audio, CB & Ham Radios, GPS, & Electrical 2 12-20-2005 02:45 PM
Aftermarket head unit mount jimj911 Audio, CB & Ham Radios, GPS, & Electrical 3 04-24-2005 03:51 PM
