I wanna run my ideas through you guys! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > I wanna run my ideas through you guys!
Engo winches available at www.rockridge4wd.com! Free shippOur 2014 DynoMax mail-in rebate March1- June 30th is here!OPTIC ARMOR WINDOWS all sale now !!!!!!!!
Unread 04-14-2014, 07:40 PM   #1
jnwolfe125
3rd Generation Jeeper
jnwolfe125's Avatar
So next week, in preparation for Jeep Beach, I'm buying a CB. I'm the kinda guy that when I buy something, I go all out and buy a nice something and I do it the right way! So I've decided on a Bearcat 880 CB with a Firestik 4' whip antenna mounted to my rear bumper. My question is about how i think I want to run the audio. SO... see if you can follow me on this one.
I'm thinking about tapping into the outputs of the factory stereo with these
and tapping into numbers 18-21
I plan on making my own 3.5mm stereo output cable (so that I can connect to the output on the CB) out of my tapped wires by using this.
Basically, I'll ground numbers 19-20 and then run 18 and 21 to L/R.
BEFORE, I hook up my stereo plug, I'll intercept the signals with this
The idea behind all this is so that I can have my cb audio running, with it's own volume control, AT THE SAME TIME as radio, cd player, AUX input (I did the Aux Input mod using the connector for an external disc changer)
So on top of whatever other audio source I'm running, I can also have my CB running at variable volume, intercepted at the factory outputs.
Thoughts?
It's a Jeep Thing.... Ya'll Understand
jnwolfe125 is offline   Reply With Quote
Unread 04-14-2014, 07:56 PM   #2
Anticanman
One eloquent mother****er
Anticanman's Avatar
Get an external speaker. They have volume controls usually on them.
So much simpler.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote
Unread 04-14-2014, 08:07 PM   #3
jnwolfe125
jnwolfe125's Avatar
But I kinda wanted to run it through my main system. I mean, I guess I could get an external speaker, but will I be able to hear it over wind noise and the radio if I have it running?
Unread 04-14-2014, 08:57 PM   #4
Indy
Youll probably hear it better out od the cb speaker than you will through blown and squelch filled factory speakers. And your cb will lead a happier life using the 8ohm it expects to see then burning up at a fraction of it.
Odds are im typing on a tablet. It takes too much effort to add some punctuation. Im lazy, get over it
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Unread 04-15-2014, 12:36 AM   #5
jnwolfe125
jnwolfe125's Avatar
What do you think of this?
http://www.audiointerrupt.com/Content/CBBCHY3OR.html#
Unread 04-15-2014, 08:48 AM   #6
PhulesAu
KISS!!!! Go to the truck stop and buy an external speaker. Mount it on the roll bar, behind your head in between the front seats. if you can't hear it at 70 mph with no top, you don't need a cb to start with.
04 L J
Travel'n Gadget Show
KE5PPH
PhulesAu is offline   Reply With Quote
Unread 04-15-2014, 03:34 PM   #7
SnowdogMarc
Thoughts?
Absolutely the worst thing ever invented. Most of the time they cut half the strands of wire leaving you with a 20ga wire instead of 16ga IF your lucky.
Over time they let moisture into the wire and corrode it destroying whats left of the strands until the device no longer works.
Best way to install a CB is run the wires directly to the battery since the battery will also act as a filter for "Some" of the elect noise.
If you must connect it to your stereo please do it the right way and install some heat shrink butt connectors to the wires you use. I've personally had to repair more than one install where the gator crimps have failed or not even made connection but look fine visually.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
