i need a new cb! - JeepForum.com
post #1 of 13 Old 07-18-2012, 09:19 AM Thread Starter
mdezeeuw
i need a new cb!
I am going to buy the Rugged Ridge 13551.09 CB Radio Dash Mount for my 2002 tj. What is the best cb to get for this app.
mike
mdezeeuw is offline
post #2 of 13 Old 07-18-2012, 10:06 AM
pavemntoptional
1981 CJ8
pavemntoptional is offline
post #3 of 13 Old 07-20-2012, 09:00 AM Thread Starter
mdezeeuw
I really like the mount i posted. Just like to know what cb works best for it.
mdezeeuw is offline
post #4 of 13 Old 07-20-2012, 09:29 AM
pavemntoptional
1981 CJ8
Sorry I hit the wrong link.. This CB works very good and in the one I install the most of. the key is to make sure the antennna is tunable and have the CB tuned to the ant.
http://www.pavementoptional.com/cobr...pact-cb-radio/
post #5 of 13 Old 07-20-2012, 10:37 AM Thread Starter
mdezeeuw
ok, now how do I know if my ant is tunable? i have one on there now. I also have a Cobra 29LTD classic but it is just to big and i have a red ant light on it all the time and found my cable has a break in it.
mdezeeuw is offline
post #6 of 13 Old 07-20-2012, 11:14 AM
pavemntoptional
1981 CJ8
that radio is to big to fit on that mount. do you know what brand / model number your ant is. Does it have a rubber cap on the top of it. if it does it should have a set screw or a threaded post on the top to adjust the height of the ant. Some are not adustable, or had to be cut to the right length
post #7 of 13 Old 07-20-2012, 11:19 AM
pavemntoptional
1981 CJ8
you will also need a SWR meter to adjust the the ant. Radio shack has them pretty cheap
post #8 of 13 Old 07-20-2012, 04:00 PM Thread Starter
mdezeeuw
i can cut it it has a rubber cap and I will also look for the SWR meter. thank you !
mdezeeuw is offline
post #9 of 13 Old 07-21-2012, 10:46 PM
kb2seo
First thing to do it get a reading from the antenna with a reliable SWR meter- The ones sold in truck stops and The cheap ones at rad shack can be off a bit. Check out MFJ site. The simple meters are going to be more accurate. Also- BE SURE that the SWR meter you get will cover the intended frequency range 9most ham radio meters for CB use are "HF" meters. Anything that says 6 meter ,2 meter or the like are meant for VHF use. And finally, avaoid using "Matchers" or tuners. If the radio is stock, that is LEGAL- it will put out 4 watts max. these guys who "tune up" CB's rarely know what they are doing, to push the wattage and Audio is only going to shorten the life of the radio and the extra 3-5 watts do not make any difference at the receiver end. Like the guys are saying- Be sure the antenna is in tune, the little stubby antennas are no where near as efficent as a 109 inch whip- which is a full Quarter wave on the cb band. Many antennas make claims of being 5/8 wave, impossible gain claims too- the rule of thumb is simple: If it was a coil, or wrapped, 9in other words, any antenna shorter than a physical quarter wave -about 8 feet long) its not allowing full power output. a true gain antenna will be longer than 8 feet. Dual "trucker" antennas are not efficent on cars or jeeps. they are designed to work with trucks with trailers for a reason. The signal will follow the on coming traffic and what is behind them the strongest, anything off the sides, Perpendicular to the truck is not as strong. Your best mounting option, although not easy to do on a jeep in the top middle, Next best is to get the base as high away from the road as you can, and mount it on the side of the jeep. Nest best would be on the tailbate As far away from your spare as you can. Ball mounts or edge mounts that have a set screw that can make metal to metal contact will provide the least noise and best "counter poise". finally, I have seen some guys use a "Magnet Mount" like a K-40 on the hod. although it will work, you are running a high rish of sending unwanter RF to the computer as well as picking up noise from the engine bot. the final mounting point would be a right angle bracket (most ham radio supplies have em- It will allow you to mount the antenna behind the mirror and you can use a stud -3/8x 20 threaded to mount a 4 foot francis or firestick. a little thought now will keep you from not being heard in the future! feel free tp email me at my yahoo account- I'll send a few photos of what i have done for my radio setups.
Good luck,
Drew, KB2SEO
kb2seo is offline
post #10 of 13 Old 07-22-2012, 08:18 PM Thread Starter
mdezeeuw
Thank is a lot of information, i thank you for it!
mdezeeuw is offline
post #11 of 13 Old 07-23-2012, 12:16 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've been tuning ham, cb, military, and commercial antennas since the mid sixties using everything from <$20 Radio Shack swr meters to high-end Bird swr meters and digital antenna analyzers... and for the job of simply showing when the lowest (the dip in) swr has been achieved while adjusting the antenna's length, a cheap swr meter does that job as well as any of them. All an swr meter needs to indicate is the amount of reflected power and when it indicates the lowest amount of reflected power, an easy task, that indicates the lowest amount of swr has been achieved which indicates the antenna is at its optimal length.
When do you need a better quality swr meter? Only when you need to know the antenna's precise SWR number as would only be required for an official log book like for the government, commercial or military.
Gone on vacation until August 25.
Jerry Bransford is offline
post #12 of 13 Old 07-23-2012, 06:52 AM
Ross
mike
If you like to drive with your doors off I would be careful with your mike hanging the CB mounted there. Mics have a tendency to wander around. If you mount the CB there the mike could easily end up out the door.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #13 of 13 Old 07-24-2012, 10:27 AM Thread Starter
mdezeeuw
o ya, so true. ok thanks.
mdezeeuw is offline
