I know this has been discussed to death but... - JeepForum.com
post #1 of 9 Old 08-26-2013, 03:24 PM Thread Starter
turbogus
1978 CJ5
Hi gang, this isn't on 'Black Betty' my '78 CJ5 but it is of an electrical nature so I'm hoping it crosses (the folks here are so helpful and knowledgable)
I've got a dual battery setup that's worked fine in 'Easy Bake' my '81 Ford panel van and neglectful of battery maintenance I let enough water gas out of the secondary battery to expose the plates (this battery was 11 years old) so I went down to Costco to get another Johnson Controls manufactured battery that I've had such good luck with over the years. I put it in the primary position and post charging did my dialy commute to work (11 miles one way) no problems even when returning home but overnight it seems the thing discharged at a fantastic rate. Firing up the alternator belts (2) squealed and I saw the ammeter jump far beyond where it normally rests. In recent days I've taken to removing the negative battery cable each time I park it and charge it each night. Could this be a defective battery? Any insights would be great as I'm still working 7 days a week and have little time for automotive repairs.
Thanks and a lift of the lynch lid.
Gus
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #2 of 9 Old 08-29-2013, 07:28 AM Thread Starter
turbogus
1978 CJ5
Well testing at the battery post for a power drain with a test light and ratz, somethings grounding out.
turbogus is offline
post #3 of 9 Old 08-29-2013, 09:50 AM
JeepNicholson
Get a helper and pull and replace fuses until it stops, that way at least you can narrow down where to look.
JeepNicholson is offline
post #4 of 9 Old 08-29-2013, 11:33 AM Thread Starter
turbogus
1978 CJ5
It's a way to go but my helper go to guy has knee back trouble of late and is bedridden most days.
turbogus is offline
post #5 of 9 Old 08-29-2013, 12:14 PM
JeepNicholson
Well, you can do it alone, it'll just take a while running back and forth between the fuse panel and the battery
post #6 of 9 Old 08-30-2013, 07:30 AM Thread Starter
turbogus
1978 CJ5
Okay, as it turns out the engine compartment light (somes on when hood is in the open position) was what was giving me the reading with the test light. Once disconnected the test light was off.
So, as it's not a drain as it turns out, I'm now mentally struggling with what could be causing the new symptoms.
Prior to any of these issues 'Easy Bake' ran out fine, winter and summer without any electrical anomolies and even at fast idle no belt squeal. It's only been for a couple of weeks now when I fire up in the morning there's a 15amp jump shown by the ammeter and the dual pulley/dual belts squeal like a banshee. That is, until the charging system catches up 3-5 seconds later.
I ran a hydrometer test and all cells (of the new battery) are normal save one on the end shows recharge 1225 (red area or hydrometer) specific gravity all others are running between 1250 and 1300 (white to green area on hydrometer) on this new (last weekend) battery. I reckon I should return and immediately test the replacement eh?
turbogus is offline
post #7 of 9 Old 08-30-2013, 05:49 PM
JPNinPA
You say you have a dual battery. Are you sure the other battery isn't draining the new one? A weak cell is all it takes.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #8 of 9 Old 08-31-2013, 07:16 AM Thread Starter
turbogus
1978 CJ5
The other battery (formerly the run battery) is running between 1300-1275 on all cells. The only reason the new battery replaced it is the secondary battery went kaput after 11 years, so the former run battery is in it's place.
turbogus is offline
post #9 of 9 Old 09-27-2013, 03:05 PM Thread Starter
turbogus
1978 CJ5
Well KISS, The dual belts were skipping, and that is what the problem was.
turbogus is offline
