How to Speaker Upgrade Tutorial: 4x6" to 5.25" (Lots of pics) - Page 8 - JeepForum.com
 1Likes
post #106 of 142 Old 04-11-2013, 07:44 PM
05Unlimited
Originally Posted by esad_b View Post
Any 4x6 speaker just doesn't have enough kick in it for you to notice the particular speaker upfront. The 5.25 however does somewhat and you can hear the different between the two speakers.
There is consoles that came in jeeps that had the 7 speaker setup from the factory which had the sub right inside the console. I've seen a guide on here before how a guy turned his ordinary console into a sub one. Or you can just look on the classifieds and find a console that is sub ready?
I do know that the stock sub in the console is not that good tho and also recall seeing a thread of how some members actually upgrade the stock sub from the console to something aftermarket.
Also you wouldn't need an amp if you were to upgrade your front and rear speakers. I have 5.25 upfront and 6.5 in the rear, no issues and for me it sounds great.
Sent from the I-device using an APP
An amp makes ALL the difference in the world. I have a small amp (KTP-445) that only puts out 45 watts RMS per channel but it made a HUGE difference in my 5.25 / 6.5 Polk combo. If you drive with the top and/or doors off above 35 MPH you're really going to need an amp. Even at low volumes it made a big difference in mine. The stock head unit sounded like crap through nice speakers. I tried it but didn't tolerate it long at all.
2005 LJ, NSG-370 6-spd (close-ratio), 3.73's, three tops incl. custom Sunrider-Safari top, 38"x22" hardtop sunroof, OME 2.5", JKS 1.25 BL/1.0 MML, seats 2"^, 285/75/16 Duratracs, Ion 171's (16x8), Alpine CDE135-BT/KTP-445/Polk521Db/650Db, full soft/hard doors, Harley L.Stms, "I swear my Jeep is staying stock"
05Unlimited is offline
post #107 of 142 Old 04-11-2013, 09:32 PM
NalinMFG
Check out this neat little amp install:
http://www.jeepz.com/forum/product-r...p-bracket.html
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #108 of 142 Old 04-12-2013, 11:36 AM
05Unlimited
Pretty cool, might do that if/when I add a sub.
post #109 of 142 Old 04-29-2013, 06:58 AM Thread Starter
esad_b
I get that an AMP would make a difference, but I think his actual question was more along the lines "does he NEED an amp to run these speakers.."
But I'm sure an AMP would give it that extra kick, especially on top/door off days.
esad_b is offline
post #110 of 142 Old 04-29-2013, 08:51 AM
05Unlimited
No doubt. I was just surprised you said it "sounds great" even without an amp. That just wasn't my experience at all, but maybe for whatever reason mine didn't sound as good as yours set up like that.
post #111 of 142 Old 05-04-2013, 11:44 PM
Zulu412
everyone thats purchased the Nalin/polk packages, where are you guys mounting the crossovers. I can't decide on best spot. PLEASE HELP
It's all Irie in the Steel City
Zulu412 is offline
post #112 of 142 Old 05-05-2013, 12:53 PM
NalinMFG
Have you looked at inside the panel under steering wheel and inside the glovebox?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #113 of 142 Old 07-24-2013, 07:46 PM
NalinMFG
May be a dumb question; so you can remove the tweeters from your existing DB521's and place them in these brackets? So far this is my favorite as far as that goes, although I fear they might get kicked or get wet. Better than up in the dash in your face though IMO.
I've been asked this a few times now so I want to make sure that this information is available for the masses.
Coaxial speakers, like the DB521, have tweeters that are literally part of the speaker and cannot be removed to be mounted in my tweeter bracket:
Component sets, like the DB5251, have everything mounted separately. A component set consists of the speakers, crossovers, and tweeters. Note how there is no way to mount the tweeter in the center of a component speaker(think of it like a mini subwoofer and the tweeter takes care of the highs). This is the type of setup that the tweeter mounts are made for.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #114 of 142 Old 04-05-2014, 10:40 PM
ShizfunK
Front Speakers Location: Dash
Left Front Speaker Wire (+): Brown/Red
Left Front Speaker Wire (-): Green
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Purple
Found this on the web, can anyone confirm?
Keep seeing conflicting posts on here.
This is for 98 TJ
ShizfunK is offline
post #115 of 142 Old 04-06-2014, 12:57 PM
ShizfunK
Bought the adapters and all was great except two problems.
1. When i rotate light switch it hits the plate. (Not too big of a deal)
2. Driver side speaker will work until I mount the plate to dash.
Not Nalin mounts bought these before discovering this thread. Are they side specific?
Mounts I have http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Do I need to move the grounds attached below? The speaker crackles then the head unit says failure on display. Any help would be greatly appreciated.
Edit: Upon further testing same problem when i switched the sides of the speakers. Must have got a defective speaker. And switched plates, not hitting headlight switch anymore.
ShizfunK is offline
post #116 of 142 Old 04-07-2014, 05:41 AM Thread Starter
esad_b
1) sounds like you might have the plates reversed.
2) sounds like a grounding problem between plate and speaker. Since the speaker works until you mount it, clearly that means you short circuit something, check if anything is loose on the speaker. After reading your wiring info, and responding below.. it does appear like you got your polarities flipped.
esad_b is offline
post #117 of 142 Old 04-07-2014, 05:48 AM Thread Starter
esad_b
This is for 98 TJ
This is for a 97 TJ, but I am sure its the same. Straight from the service manual.
left front (-)= brown/red
left front (+) = dark green
right front (-) = dark blue
right front (+) = voilet
Seems like you got your stuff reveresd tho...
esad_b is offline
post #118 of 142 Old 04-07-2014, 05:55 PM
ShizfunK
I had it wired the way you said as the way in my post sounded tinny. I'm returning those speakers and getting the polks since everyone has good luck with them. So those ends you put on the wires just slip on the posts of the speaker?
ShizfunK is offline
post #119 of 142 Old 04-07-2014, 06:08 PM Thread Starter
esad_b
Yea exactly, you can get those little connectors at any electrical store. Just splice them in then they can slide on the posts of the speaker. This will make a better and sturdier connection than just trying to tie up/wrap the wire around the posts of the speakers.
esad_b is offline
post #120 of 142 Old 04-09-2014, 08:55 AM
NalinMFG
Post a picture.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
An odd tire site that I tripped over... lots of "tractor tires" Bennettj13 Tires & Wheels 1 01-22-2010 01:34 PM
Daul 10" Inseat Sub Box With Lots Of Pics! nitwit527 Audio, CB & Ham Radios, GPS, & Electrical 11 02-24-2007 09:13 PM
Radio speaker "buzz" thinkwoods Audio, CB & Ham Radios, GPS, & Electrical 2 08-03-2006 10:42 AM
Lift and Tire Pics -- RE 3.5" with 1" BL 1" MML & 32x12.50 Tires newgene Tires & Wheels 14 06-22-2005 11:24 AM
4"x6" Speaker Replacement MCanavan Audio, CB & Ham Radios, GPS, & Electrical 44 03-26-2005 06:06 PM
