How to Speaker Upgrade Tutorial: 4x6" to 5.25" (Lots of pics) - Page 3 - JeepForum.com
 1Likes
post #31 of 142 Old 02-02-2012, 06:53 AM
02WranglerTJ
How much polyfill do you need?
02WranglerTJ is offline
post #32 of 142 Old 02-02-2012, 08:48 AM
gily25
Your goal is to break up the backwave of the speaker do enough to occupy the space behind the speaker (a lil different than packing a sub box) but loosely pushed in...not crammed in. It gets caught in the speaker basket and wiring so don worry about it falling out.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #33 of 142 Old 02-02-2012, 08:15 PM
AKGeo
Originally Posted by geocash View Post
AK - did you use the same Polk Audio speakers as shown above?
Yup. With the MTX brackets it was a tight fit to the dash frame on the passenger side but I don't hear anything that sounds like it might have a problem with contact with the speaker surround. I didn't polyfil behind them, but I might do that as well as the sound bar sometime soon to see if it offers any more sound quality. I still have to order and install an amp to drive all the speakers (also have Polk shallow 6.5's in the sound bar. I suggest the standard 6.5's unless you run a subwoofer.) and install my Kenwood marine stereo, so I'll be running new speaker wires anyway. May as well get it all taken care of at once.
AKGeo is offline
post #34 of 142 Old 02-03-2012, 09:18 AM
DanZ51
My 04 TJ came from the PO with Alpine SPS-510 5.25" coaxials front and rear. Better than stock but 87db rating I'd like to swap out for something a little more efficient but for now these will do.
I added polyfill front and rear. The problems is I don't get much sound out of the front speakers as oppose to the rear speakers mounted in the pods. Would an (small) enclosure up front make that much of a difference?
"I will always be an American Soldier"
DanZ51 is offline
post #35 of 142 Old 02-03-2012, 12:42 PM
clintrivera
More specifically the polyfill in this application is to lessen the chance that the sound from the rear of the speaker doesn't cancel out the sound from the front of the speaker. If you were able to completely "enclose" the rear of the speaker with fiberglass or something airtight you would get better bass and mid range.
You can test out the difference this makes with a home system easily. Simply reverse the wires on one of the speakers and you will know what is happening with the front speaker setup in a jeep.
clintrivera is offline
post #36 of 142 Old 02-03-2012, 05:52 PM
PCfirefighter
Great write up and good idea on the poly
PCfirefighter is offline
post #37 of 142 Old 02-05-2012, 08:15 AM Thread Starter
esad_b
I picked up a smaller sized pillow from Walmart cut it open. Didn't use all the polyfill either it just pushed it the back of the speakers until I noticed it was getting full.
Exactly
Thanks! Glad it's helping others out.
esad_b is offline
post #38 of 142 Old 02-05-2012, 08:17 AM Thread Starter
esad_b
Originally Posted by 4x4Brit View Post
Haven't done this yet but it's on the to do list. I'm interested to see what difference it makes.
I wish I would of taken a sound clip prior to polyfill and afterwards but I really didn't
But it just sounds deeper I know that from my previous speakers that didn't have anything back there. Plus for the $2 pillow I bought to rip the polyfill out of it it was worth it either way
esad_b is offline
post #39 of 142 Old 02-05-2012, 06:26 PM
AKGeo
I just stuffed some polyfill behind my front speakers...didn't notice too much of a difference but it was an old pillow that was going in the trash anyway. And I'm sure driving it on the highway will make it more noticeable. I have another pillow waiting to be used to fill the soundbar as well.
AKGeo is offline
post #40 of 142 Old 02-18-2012, 09:49 AM
BamaJeepman21
Man this adapter sounds great. I'm extremely new to audio and I'm just plain not good at this stuff. What are some of the best 5.25" speakers? A lot of people in this thread have had to splice wires. Can you not get speakers that plug in?
How hard is it to get 6.25" speakers in the sounds bar? One said it was a pain in the *** but didn't go into detail.
-Jack
BamaJeepman21 is offline
post #41 of 142 Old 02-18-2012, 11:15 AM
NalinMFG
http://www.amazon.com/dp/B0002BEQWK?tag=diecastpro&camp=14573&creative=327641&linkCode=as1&creativeASIN=B0002BEQWK&adid=15JM1KS3T9054TJV9Y79&&ref-refURL=http%3A%2F%2F4x4icon.com%2Foffroad%2F121606_cherokee_speakers%2Findex.htm
I recall them being cheaper somewhere else though, may try searching the part number.
The most popular speaker in my experience has been Polk's DB521.
http://www.amazon.com/Polk-Audio-5-25-Inch-Coaxial-Speakers/dp/B000P0PF8C/ref=sr_1_2?s=electronics&ie=UTF8&qid=1329588870&sr=1-2
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #42 of 142 Old 02-18-2012, 12:50 PM Thread Starter
esad_b
DB521 is your best bang for the buck.
The splicing of wires will be necessary as the speaker is not a stock component. It's quite easy to do nothing about it really, you can splice connectors and then plus the speakers in if it would help
6.25" speakers in the soundbar can vary because different 6.25" speakers vary slightly in size and throw stuff off and make it harder to mount. But either way you will need to make the soundbar hole a bit bigger for the speaker to fit in any case.
esad_b is offline
post #43 of 142 Old 02-18-2012, 02:11 PM
AKGeo
Polk's matching 6.5" speakers go into the soundbar without any mods to the bar itself.
AKGeo is offline
post #44 of 142 Old 04-19-2012, 07:34 PM
axxegrinder
Just wanted to add; I cut the bar with a pair of 18 gauge tin-snips that I paid $15 for. Just wanted to add this in case folks are thinking they need a higher priced Dremel or other tool.
- Chris
Sammym11 likes this.
axxegrinder is offline
post #45 of 142 Old 04-20-2012, 05:35 AM Thread Starter
esad_b
- Chris
I will add your comment to the original post at the very top
Thanks for the input!
esad_b is offline
An odd tire site that I tripped over... lots of "tractor tires" Bennettj13 Tires & Wheels 1 01-22-2010 01:34 PM
Daul 10" Inseat Sub Box With Lots Of Pics! nitwit527 Audio, CB & Ham Radios, GPS, & Electrical 11 02-24-2007 09:13 PM
Radio speaker "buzz" thinkwoods Audio, CB & Ham Radios, GPS, & Electrical 2 08-03-2006 10:42 AM
Lift and Tire Pics -- RE 3.5" with 1" BL 1" MML & 32x12.50 Tires newgene Tires & Wheels 14 06-22-2005 11:24 AM
4"x6" Speaker Replacement MCanavan Audio, CB & Ham Radios, GPS, & Electrical 44 03-26-2005 06:06 PM
