How to Speaker Upgrade Tutorial: 4x6" to 5.25" (Lots of pics) - Page 2 - JeepForum.com
 1Likes
post #16 of 142 Old 12-31-2011, 11:13 AM
geocash
Originally Posted by AKGeo View Post
Yes, the speaker covers fit back on. My TJ, even with the MTX mounts that tilt the speaker up to vertical instead of contouring to the dash profile, has them on it and it doesn't look like anything's changed.
AK - did you use the same Polk Audio speakers as shown above?
geocash is offline
post #17 of 142 Old 12-31-2011, 02:17 PM
Holm-z
Holm-z's Avatar
very nice write up! Ill be doing this mod this spring!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #18 of 142 Old 12-31-2011, 02:30 PM
Gary2
I went from an OE to an aftermarket 4x6 to a 5.25 and in the end only because it is in an actual enclosure I went with a Later TJs infinity option dash speakers that are mounted in pods . For a mid range speaker the pods sound better . I am running an Alpine 45x4 amp . I installed an MB Quart crossover which feeds the pods in the dash and the MB Quart tweeters mounted on the upper corners of the dash .
Gary2 is offline
post #19 of 142 Old 01-13-2012, 06:53 AM Thread Starter
esad_b
Probably did, most everyone uses these Polks up front they sound amazing for the price you pay. Plus not a whole lot of that good 5.25" speakers around.
Just add some polyfill like I suggested.
esad_b is offline
post #20 of 142 Old 01-13-2012, 07:50 AM
church
Rubi-Roo
church's Avatar
I added the 6.5" Polks to my Pods and the 5.25" up front with the Nalin adapters. The fronts were very easy to install with the adapters. The rears were a total pain! I like the fact that you can aim the highs on the 5.25's.
On the rear I had to cut off the lip all the way around the 6.5 to even get them to fit in the rear pods. Once it was all done, the sound is amazing. I cant believe how doing a little upgrade like this makes a huge difference in sound.
Got a pair of Nalins front speaker adapters for sale. (no screws)
church is offline
post #21 of 142 Old 01-13-2012, 06:03 PM
4x4Brit
I ended up buying the nalin plates and 4x5.25 Polks just recently. I am new to installing car audio and I'm wondering what is the easiest way to wire these speakers. Snip the factory plug and solder to the posts on the Polks? Or use some other kind of connector?
Thanks.
4x4Brit is offline
post #22 of 142 Old 01-13-2012, 07:43 PM
church
Rubi-Roo
church's Avatar
Snip the factory plug and solder to the posts on the Polks.
church is offline
post #23 of 142 Old 01-15-2012, 07:06 AM Thread Starter
esad_b
Thanks.
Whatever you feel comfortable with, I spliced in the connectors as shown on the pic above and then just slid then over the posts. Soldering is good idea but if you ever decide to remove them then you gotta break the connection.
I find the posts on the speakers sometimes are not very strong/heavy duty so breaking the post off trying to take wire off could cause some damage.
You can always solder the actual connector to the wire then still use connector over posts for easy removal down the road. At the end tho it's all your call
esad_b is offline
post #24 of 142 Old 01-30-2012, 02:35 PM
02WranglerTJ
NIce write up! I got really lucky and had the 7 speaker system. I didn't even have to do the metal trimming, great fit!
02WranglerTJ is offline
post #25 of 142 Old 01-30-2012, 03:57 PM
4x4Brit
So ended up using female spade connectors crushed onto the wire after snipping the factory plug off. So far, so good. And like the previous poster, I also didn't have to cut anything. The Nalin adapters work nicely.
Build Thread:
Website:
Facebook Page: https://www.facebook.com/Warmachines702
4x4Brit is offline
post #26 of 142 Old 02-01-2012, 04:32 PM Thread Starter
esad_b
7 speaker system makes quite a diff in the ti! Always thought about adding that sub in the console but never got around to it.
Both you guys must have newer TJs then? I think pre 02 has to cut the dash part of like I showed.
Don't forget to add polyfill!!!
esad_b is offline
post #27 of 142 Old 02-01-2012, 04:43 PM
02WranglerTJ
I have an 02. Sub makes a Nice difference. Id like to get a 4.channel amp though.
post #28 of 142 Old 02-01-2012, 07:16 PM
Dickpalmer
I did this to my 00'TJ. It was tough cutting the braces until I remembered I had tin snips. Much much easier and no sparks or residue. I used some silicone between the speaker and mount to reduce the chance of vibration. I love these write ups. They make everything easier. Thanks.
Dickpalmer is offline
post #29 of 142 Old 02-01-2012, 09:15 PM
NalinMFG
Correct. 1997-2002 require trimming of the subframe brace. 2003-2006 bolt on without modification.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #30 of 142 Old 02-02-2012, 02:23 AM
4x4Brit
Haven't done this yet but it's on the to do list. I'm interested to see what difference it makes.
Build Thread:
Website:
4x4Brit is offline
An odd tire site that I tripped over... lots of "tractor tires" Bennettj13 Tires & Wheels 1 01-22-2010 02:34 PM
Daul 10" Inseat Sub Box With Lots Of Pics! nitwit527 Audio, CB & Ham Radios, GPS, & Electrical 11 02-24-2007 10:13 PM
Radio speaker "buzz" thinkwoods Audio, CB & Ham Radios, GPS, & Electrical 2 08-03-2006 11:42 AM
Lift and Tire Pics -- RE 3.5" with 1" BL 1" MML & 32x12.50 Tires newgene Tires & Wheels 14 06-22-2005 12:24 PM
4"x6" Speaker Replacement MCanavan Audio, CB & Ham Radios, GPS, & Electrical 44 03-26-2005 07:06 PM
