Quantcast How should I splice 10 Gauge Wire - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > How should I splice 10 Gauge Wire
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 11-19-2009, 06:03 AM   #1
bobmcc81
I'm running a pair of 130 W lights on the front bumper and running 10 gauge wire back to the relay. I don't think I need to run two home runs of wire to the lights I was going to run one line to the farthest light and splice in the other light.
Is there a good way to do this? On 14 gauge stuff I trim back, wrap, solder and heat shrink but I'm not sure I can get 10 gauge hot enough to solder and not melt the insulation.
Thanks for any tips
Bob
'95 Wrangler
bobmcc81 is offline   Reply With Quote
Old 11-19-2009, 09:27 AM   #2
slowride99
I would mount the relay close to frt bumber and run home runs to lights from relay.
99 GC WJ Limited 4.0
All stock with several WJ issues
slowride99 is offline   Reply With Quote
Old 11-19-2009, 10:02 AM   #3
KnacK
Even though more is better, 10 ga is overkill for just 2 lights.
Now with that being said, if you have one of those soldering guns that are about 100 to 140 watt, you should be fine. I typically strip back an inch on either side, slide my heat shrink on, then push the wires together end to end then heat and solder. Makes a good connection and doesn't get much thicker than the original strand of wire.
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline   Reply With Quote
Old 11-19-2009, 10:12 AM   #4
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You really only need 12G for those lights and even then, 12 is "extra"
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 11-19-2009, 02:36 PM   #5
bobmcc81
Ok thanks for the input. I'll go back to 12 and make two home runs to the relay which I like up by the battery and fuse block all together.
Bob
'95 Wrangler
Glock Forum
