How To Replace The Factory Subwoofer - Page 29 - JeepForum.com
 4Likes
post #421 of 433 Old 02-04-2017, 08:51 PM
esad_b
Can someone confirm, whether I should be looking at 1ohm or 2ohm subs?
esad_b is offline
post #422 of 433 Old 02-05-2017, 06:15 PM
aogmitch
Originally Posted by esad_b View Post
I've narrowed down my thing to the kicker how ever I am unsure what the difference is between 40cwrt672 and 43cwrt672.
I am curious if these subs require a certain amount from the amp to run at all?
I'll shoot you a pm.
I believe the 43 is the newest version, as Crutchfied and Amazon show the 40 as unavailable. The 43 is a dual voice coil 1 ohm speaker as was the 40. I just ordered the 43 a couple days ago as my sub just failed this last week.
2004 Rubicon, 5-spd, RC 2.5" Lift w/RC 2.2 Shocks, 1.25" BL, MML, RC 2.2 Stabilizer, Currie Antirock, 33x12.5-15 BFG MT KMs on Black Steel Wheels, Highrock Rear Bumper, Warn Front Bumper, Warn M8000, A to Z Rocker Gaurds, Pioneer DEH P5000UB, Eclipse 4ch Amp, Infinity 6.5 and 5.5 Speakers, Factory Sub. More to come.
aogmitch is offline
post #423 of 433 Old 02-05-2017, 06:35 PM
esad_b
You are right, the 43 is the new version. However the 672 is 2ohms. While the 671 is 1ohm.
I believe the stock unit is a 2ohm I hope someone can confirm?
esad_b is offline
post #424 of 433 Old 02-19-2017, 01:51 PM
Submarineaz
great write up, I would have bought a dual voice coil sub if I had read this first. I ended up using red and black wires, but both wires powered the sub.
Submarineaz is offline
post #425 of 433 Old 02-20-2017, 11:05 AM
happy_gopher
I did the Pyramid 6.5" install this weekend. It sounds pretty good and this guide was very helpful.
However, I would have rather used a dual voicecoil speaker. Hindsight right? I just found this on Amazon Prime..AUDIOPIPE-TS-V6R
(my post count is too low to post the link, sorry)
For the price, I just might buy it and compare the two.
Happy_G
05 Rubicon, my third and final Jeep.
Gone:
2000 Cherokee, 1951 CJ3A
happy_gopher is offline
post #426 of 433 Old 02-20-2017, 01:36 PM
esad_b
Can someone confirm how is the stock sub wired?
I am assuming its a 2ohm DVC sub that is wired in parallel for a 1ohm load? So I would be tieing the black to black wires, red to red.
And just tape off the other two?
xxdabroxx likes this.
esad_b is offline
post #427 of 433 Old 02-22-2017, 08:27 AM
esad_b
Think I've answered my own question. Since the 43CWRT672 is a 2ohm Dual Voice Coil it gets wired the same way as the stock sub. No need to cut off/tape other wires. Since there was a lot of random guessing going on in some of these posts and no clear definition on what wire is what I went to test the old sub with a 9V battery and determined;
In order to find out exactly whats what take the 9V battery and touch the two tips on the sub and watch if the sub pushes AWAY or IN from the magnet. If it pushes out/away from magnet then you have polarity on battery matching polarity on the sub. If its pulls in then its flipped.
To then determine what wire is what if you look at the tabs on the wires themselves, 1 metal clip is bigger than the other so this helps you nail down which one goes over what post and eliminate if its positive or negative.
For my 05 LJ the 4 wires that were attached to the sub are;
Black - positive
Red - negative
White - positive
Brown - negative
aspider likes this.
esad_b is offline
post #428 of 433 Old 02-22-2017, 09:34 AM
GreenLJ
That's helpful, going to attempt this on my LJ soon. Thinking Kicker.
Black - positive
Red - negative
White - positive
Brown - negative
GreenLJ is offline
post #429 of 433 Old 02-26-2017, 05:07 PM
esad_b
Well swapped in the kicker, after some trimming and polyfill I can vouch that the kicker makes quite a difference over the stock sub.
I know most on here are saying they couldn't compare between the two as their stock sub was blown when they got hold of their Jeep but I can say that my stock sub worked until a few months back. With this kicker in the sound is much deeper I find, also it doesnt rattle like the stock sub did if I turned up the music any.
Anyways some shots of it installed, pretty straight forward.
esad_b is offline
post #430 of 433 Old 02-28-2017, 10:55 AM
xxdabroxx
What part number did you use? Nevermind, found it above. Looks good BTW.
xxdabroxx is offline
post #431 of 433 Old 03-25-2017, 07:25 PM
hunter_ace
2001 wrangler tj se
here is the correct wiring for sub with relay.
Car Radio Constant 12v+ Wire: Pink/White
Car Radio Switched 12v+ Wire: Pink
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Stereo Amp Trigger Wire: lime or light green
Left Front Speaker Positive Wire (+): Brown/Red
Left Front Speaker Negative Wire (-): Green
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Violet
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Red
The amp uses the rear speaker wires for a source the +/_ are the same color codes going into amp. the black/red is the 12 volt + from the relay, the black/white is the ground.
now as far as the colors on both of the voice coil inputs on the speaker i used a replacement kit so no problem with that for me .
But just for a bit of info all speakers are made with the same positive and neg orientation .
With terminals facing you looking down at magnet (or the rear of speaker) left should be negative, right should be positive.
smaller sized terminal is almost always neg.
i have not run across any speakers that do not follow the industry standard. I am sure there probably is though.
Hope this helps someone i just spent better part of few hrs figuring it out in my daughters jeep after her boyfriend tried to put a aftermarket stereo in and was baffled by the sub setup. he could not figure out why sub quit working.
aspider likes this.
hunter_ace is offline
post #432 of 433 Old 05-09-2017, 11:18 PM
brendend
Sorry to dig up an old thread. For those who are running the kicker43cwrt672 how does is sound without an external amp? I have the pyramid sub in now and it sounds just like another speaker.
brendend is offline
post #433 of 433 Old 05-12-2017, 08:31 PM
esad_b
The sub has some good kick for it considering its only fed with a 75watt stock amp. I had the stock sub which actually worked in my Jeep until just last fall when the cone separated and the bass is certainly deeper on the Kicker I find.
If my stock one hadn't broke I wouldn't of changed it, but if its dead yah its worth the money.
esad_b is offline
Factory subwoofer mpeak Audio, CB & Ham Radios, GPS, & Electrical 1 04-12-2007 03:22 PM
Good subwoofer to replace stock. jreuscher Audio, CB & Ham Radios, GPS, & Electrical 5 12-19-2006 08:58 AM
factory subwoofer help please!!!!!!! wrangler8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-31-2005 03:30 AM
Factory Subwoofer- need some help Xtreme04 Audio, CB & Ham Radios, GPS, & Electrical 7 12-29-2004 09:45 AM
factory subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 2 10-03-2002 04:56 PM
