How To Replace The Factory Subwoofer - Page 26 - JeepForum.com
 2Likes
post #376 of 431 Old 01-05-2014, 03:55 PM
dbsanders
Installed the Pyramid today. Not as much bass output as stock (as expected), but better than it being blown.
dbsanders is offline
post #377 of 431 Old 01-19-2014, 08:57 PM
raif281
subscribed
raif281 is offline
post #378 of 431 Old 01-21-2014, 10:31 AM
CropDr
Originally Posted by oTTo97Sahara View Post
Has anyone tried both the Kicker 1ohm and the quadratec replacement? which one sounds better?
I'm wondering the same thing. It looks like the Kicker 652 2 ohm has been discontinued, but you can still get the 651. I like the fact that the Kickers have more than 4 mounting holes...I figure 8 screws has to hold better than 4, especially since you are not going back in the OEM holes.
I don't know squat about car speekers...what difference does the ohm reading make?
Thanks.
CropDr is offline
post #379 of 431 Old 01-22-2014, 09:35 AM
58WillysPickup
"Ohms" refers to the electrical reisistance of a speaker. You should never use a speaker with less than the minimum ohms your amplifier or stereo is designed to handle. It's okay to go higher (it will just reduce the volume) but never lower. The lower the ohms, the lower the resistance - "0" ohms would be like shorting your "+" and "-" speaker wires together. A 2 ohm speaker doesn't offer much more resistance than that, and if an amplifier is not designed to handle that kind of current it will quickly burn it up.
Regarding the 8 vs. 4 holes comment. Not wanting to try to screw into flimsy plastic, I simply cut the frame off the factory speaker to use as a mounting ring. This way I was able to use the MUCH stronger factory holes. A little trimming of the plastic spacer ring and it looks like stock (I used the el cheapo speaker because I was selling that Jeep, but should work on any of similar size). See the picture of the finished product here:
http://www.jeepforum.com/forum/attac...inal-instl.jpg
58WillysPickup is offline
post #380 of 431 Old 01-22-2014, 05:58 PM
CropDr
Originally Posted by 58WillysPickup;19644249 I simply cut the frame off the factory speaker to use as a mounting ring. This way I was able to use the MUCH stronger factory holes.
[url
http://www.jeepforum.com/forum/attachments/f20/630464d1369459921-how-replace-factory-subwoofer-final-instl.jpg[/url]
Do you have a picture without the speaker cover on? Did you just "sandwich" the new speaker between the old mounting ring and the box?
Thanks.
CropDr is offline
post #381 of 431 Old 01-29-2014, 01:38 PM
mattadams05tj
So with the kicker 40cwrt671 the wiring is basically the same as stock 2 leads per coil?
mattadams05tj is offline
post #382 of 431 Old 01-29-2014, 02:04 PM
raif281
does anybody know the mounting depth for the enclosure is?
raif281 is offline
post #383 of 431 Old 01-29-2014, 04:49 PM
mattadams05tj
The 40cwrt671 is 2 3/4
post #384 of 431 Old 02-03-2014, 07:25 PM
raif281
hey y'all my sub has lots of voice, like it sounds like it's just another speaker! what could cause this? all factory stuff
raif281 is offline
post #385 of 431 Old 02-25-2014, 06:37 PM
Jeeper69
Does any soldering need to be done?
Jeeper69 is offline
post #386 of 431 Old 02-25-2014, 06:43 PM
frenchy206
No, but it wouldn't hurt.
03 TJ Rubicon
frenchy206 is offline
post #387 of 431 Old 04-13-2014, 12:29 PM
jeepjunkytj
I just did this on my 05. Mine had two extra mounting screws in the storage area of the compartment. Also nothing worked when I hooked up the gray and brown wires. Mine needed the red and black wires hooked up. Awsome write up though. I also found my pyramid sub woofer on eBay for $13.00 shipped.
jeepjunkytj is offline
post #388 of 431 Old 04-27-2014, 01:32 PM
focotj
Thank you, OP, for a great guide and pictures. I did this yesterday in my '04, it took about 45 minutes total.
As someone mentioned above, I also had two screws inside the console securing the enclosure from the top. The red and black wires were already connected to mine, with the grey and brown taped off, so I just used those. Worked like a charm.
focotj is offline
post #389 of 431 Old 04-28-2014, 06:11 PM
58WillysPickup
Thanks.
CropDr, sorry for the delay - been away for a while.
I put thin weatherstripping foam on the back of the speaker flange to get good seal. Then I sandwiched the speaker between the trim ring I made from the old speaker and the box. Finally I used high strength double sided adhesive tape to attach the grill ring. I did have to trim the height of the grill ring so it wouldn't hit the cover. Hope this helps.
1 - Cut Flange.JPG   2 - Add Gasket.JPG   3 - Install in Box.JPG   4 - Add Ring.jpg
post #390 of 431 Old 05-11-2014, 10:00 AM
CropDr
I just did mine the same way 58Willys did. Definatly the way to go....Sadly as I was tightening down the screws I sliped and put the screwdriver through the foam ring! I have some glew drying on it right now...hopefully I can save it!
I didn't bother with making the screen fit back over the speaker....I took some black felt and glued it to the inside of the arm rest housing. We will see how long it takes to fill with dust!
CropDr is offline
Factory subwoofer mpeak Audio, CB & Ham Radios, GPS, & Electrical 1 04-12-2007 03:22 PM
Good subwoofer to replace stock. jreuscher Audio, CB & Ham Radios, GPS, & Electrical 5 12-19-2006 08:58 AM
factory subwoofer help please!!!!!!! wrangler8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-31-2005 03:30 AM
Factory Subwoofer- need some help Xtreme04 Audio, CB & Ham Radios, GPS, & Electrical 7 12-29-2004 09:45 AM
factory subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 2 10-03-2002 04:56 PM
