How To Replace The Factory Subwoofer - Page 12 - JeepForum.com
 2Likes
post #166 of 433 Old 09-22-2010, 07:57 AM
yipekya
Replaced my wife's sub this weekend. Awesome!
yipekya is offline
post #167 of 433 Old 09-23-2010, 02:04 PM
Kenshiroking
These instructions are epic. Well done!
Less talk, more rock!
Kenshiroking is offline
post #168 of 433 Old 09-24-2010, 11:34 PM
Motorep
I just installed the Kicker sub today. Ended up using the black and red wires and taped the others. I also had to buy a spacer to get the sub to seat flat. Sounds really, really, good. So good in fact that I'll be picking up a set of 6 1/2's for the factory soundbar.
Motorep is offline
post #169 of 433 Old 09-26-2010, 06:20 PM
cyberswat
Bazooka WF621.5DV
FWIW the the Bazooka forums has a thread on this as well and their techs seem to indicate you can wire the WF621.5DV voice coils in parallel to achieve the originals 1 ohm impedance ... this speaker starts at 2ohms so wiring it correctly will cut that down to 1ohm giving you the full use of the stock amp with a better quality speaker.
Quoting from their site: "Yes, the wires are for your left and right channels of the factory woofer. To connect them in parallel, you will match the positive of the left channel with the positive of the right channel, and the negative of the left channel with the negative of the right channel."
The speaker is a WF621.5DV - 6 inch 2 ohm replacement woofer and the thread on their site is OEM Replacement Woofers - Club Bazooka
cyberswat is offline
post #170 of 433 Old 09-27-2010, 08:27 AM
SirGCal
RIP
SirGCal's Avatar
Problem with Bazzooka is:
  1. They won't give out their parameters for their replacement equipment. Most likely, it's going to be severely underpowered on the stock amp which will make it not as effective as well as the box is just completely wrong. More on that in a next. But why must they hide their parameters for these subs... It's not like their tubes are some huge secret... It's a long vented box... Tear one apart and you can calculate exact specifications for their product... That's one reason I'm not a big Bazooka fan...
  2. It's a tube-replacement sub, which is a considerably large vented box design. The stock tiny enclosure is a huge difference. These subs were designed with vented enclosures specifically in mind.
  3. It's 1.6" deeper than the stock sub resulting in clearance and cooling issues (though cooling may not be a problem since it's also possibly way underpowered)...
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #171 of 433 Old 09-27-2010, 09:59 PM
odinseye84
I think its worth a shot. Underpowering has no ill effect on speakers (one of the most prevelant internet myths EVER). I agree it was intended for a large vented box, which is why they are so efficient, but I think it might work in a smaller sealed box too. I think it would be worth the time instead of running a 4 ohm sub and getting substantially less power from the amp. In any case you can return it perhaps! If I had a stock sub I would give it a shot.
odinseye84 is offline
post #172 of 433 Old 10-04-2010, 08:47 AM
munroejp
Replaced my daughter's sub this weekend in 2001 Wrangler. Went with the Pyramid and used the black and red wires. Great write up, helped alot.
munroejp is offline
post #173 of 433 Old 10-06-2010, 01:43 PM
Unlimited05kyle
problems wiring the pyramid subwoofer
This speaker sounds so much better then the stock one. Thx for the post
Unlimited05kyle is offline
post #174 of 433 Old 10-07-2010, 09:09 AM
FourbyFour
FourbyFour's Avatar
For those who are illiterate when it comes to wiring...what does that mean.."in parralel"? Is there a diagram somewhere?
Thanks
Originally Posted by Jerry Bransford View Post
You'll play hell cutting in front of any veteran waiting his turn to piss on Jane Fonda's grave and you sure as hell won't cut in front of me.
Originally Posted by DcMuff View Post
PREPOSTerous...
Originally Posted by Dead_End View Post
hurr durr I gots a truk
FourbyFour is offline
post #175 of 433 Old 10-07-2010, 12:09 PM
gily25
use a woofer wiring wizard...they will show you exactly what wires and terminals to connect.
gily25 is offline
post #176 of 433 Old 10-07-2010, 12:17 PM
FourbyFour
FourbyFour's Avatar
Thanks for the link. I didn't see an option for 2 to 1 omhs.
PREPOSTerous...
post #177 of 433 Old 10-08-2010, 06:28 AM
cyberswat
I used the bazooka speaker I linked above and it works/sounds great. You do need a good dremel to cut out plastic to get the speaker to fit inside the box. As far as wiring goes, it was a dual channel speaker so has the same positive and negative terminals that came with the factory speaker. I just switched them from left to right until they sounded the best to me and then put everything back together. I've had this installed for about a week now and it sounds absolutely great.
post #178 of 433 Old 10-08-2010, 12:21 PM
Phreak480
i was lazy and did it without the dremel. i just used some big diagonal cutters to snip the plastic away, quick and effective and nobody will ever see it anyways
Phreak480 is offline
post #179 of 433 Old 10-08-2010, 12:51 PM
FourbyFour
FourbyFour's Avatar
Is there a risk of blowing out the speaker if one accidentaly hooks up the wrong wires?
PREPOSTerous...
post #180 of 433 Old 10-11-2010, 07:24 PM
Sovereign
I use this forum often for my 03 Rubicon projects, but had to create a login to say thanks to ArcherAce for posting this detailed instruction. I opted for a 6.5" Kicker CVT65 (CompVT | KICKER) instead of the Pyramid. I paid $75 shipped, and for the increase in sound performance, I think the price difference is well worth it. Thanks again, ArcherAce.
Sovereign is offline
Factory subwoofer mpeak Audio, CB & Ham Radios, GPS, & Electrical 1 04-12-2007 03:22 PM
Good subwoofer to replace stock. jreuscher Audio, CB & Ham Radios, GPS, & Electrical 5 12-19-2006 08:58 AM
factory subwoofer help please!!!!!!! wrangler8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-31-2005 03:30 AM
Factory Subwoofer- need some help Xtreme04 Audio, CB & Ham Radios, GPS, & Electrical 7 12-29-2004 09:45 AM
factory subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 2 10-03-2002 04:56 PM
