How To Replace The Factory Subwoofer - Page 11 - JeepForum.com
 2Likes
post #151 of 433 Old 08-27-2010, 10:15 PM
AZG23
thanks for the info..I was thinking dynamat...
Brad B.
"If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick."
AZG23 is offline
post #152 of 433 Old 08-30-2010, 08:44 PM
rodnrobbin
Subwoofer
Today I replaced my blown factory subwoofer with a KICKER 10CVT65 COMPVT 6.5"SUBWOOFER 2-OHM Subwoofer using information from resent postings. I used the red (+) and black (-) wires while taping off the brown and gray. I also had to cut way some plastic so as to make room for the new subwoofer. The system now sounds great! Thanks for everyone's helpful postings!
rodnrobbin is offline
post #153 of 433 Old 08-31-2010, 01:07 PM
D3f4ult
Not sure if anyone else has done it, but I added some cotton filler in there to get rid of the hollow thump the aftermarket sub gave.
D3f4ult is offline
post #154 of 433 Old 09-02-2010, 01:48 PM
Roman68
finally replaced the factory POS sub in the wife's Unlimited yesterday...thanks a million for this write up!! i had a few extra bolts to remove from the console to get the woofer enclosure to drop but regardless, this write was a godsend.
i ended up having to hook up the red and brown wires.....all other combos didnt work- black and gray, gray and black, red and black, brown and black, etc. finally got the right combination and sound was thumpin. to be honest, i think it (pyramid woofer) sounds pretty damn good. and the wife is happy, and that is always a bonus.
so here is a question- i want to add a sub to my 2000 TJ. i have an aftermarket stereo that does have the extra outputs for a sub, but i truly have no idea where to start as far as installing one myself. is this a crazy hard job or can i get through it? anyone have any experience installing a sub into a TJ without a previous sub being wired?
thanks in advance...
2000 TJ sport- 32x10.5 BFG AT K/O2s *5spd *4.0L *Rampage Bowless SoftTop *OME 2.5" suspension lift
Roman68 is offline
post #155 of 433 Old 09-02-2010, 03:47 PM
rodnrobbin
As a measure of protection for my new subwoofer, I removed the console's 3 side screws and slid in a square piece of black fiberglass screen material. (This was slid in between the subwoofer box and the inner wall of console.) The material was then held firmly in place by the replaced screws. I purchased a roll of this screen from Walmart for a little over $5. It's not only functional but it looks factory.
post #156 of 433 Old 09-03-2010, 07:50 AM
gily25
Yeah the factory sub has a piece of grill cloth stretched over it. As long as it's not too tight or too thick it's good for keeping crumbs and coins from falling in the slats on the side.
As for the "cotton" polyfil can work wonders for small enclosures but there is a limit to how much can be put in.
For the guy with the 2000 TJ what kind of set-up do you want? Trunk filling? tailgate filling? double amps? single amp? If you just want a basic center console sub I recommend building a new enclosure and going with an 8" sub, a lot of decent powered amps come in small footprints and can be stashed in various places.
http://www.jeepforum.com/forum/f20/8...inside-257123/
gily25 is offline
post #157 of 433 Old 09-08-2010, 09:50 PM
RichardNoggin
quick question from a newb.
ive been reading on removing the sub and it always say to disconnect the battery. my sub is blown and i just want it disconnected until i replace it. will this cause problems if i just disconnect the harnesses?
RichardNoggin is offline
post #158 of 433 Old 09-08-2010, 10:05 PM
SirGCal
RIP
SirGCal's Avatar
No; that would be fine.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #159 of 433 Old 09-08-2010, 10:24 PM
RichardNoggin
awesome, thanks
post #160 of 433 Old 09-11-2010, 10:02 PM
Hollywood5
4 wires running to speaker
The subwoofer harness runs to some metal finned piece in the center counsel. Then, four wires (red, black, silver, grey) run back to the factory speaker. What is the metal finned piece and do I need to find a replacement sub with four connections? This forum seems to indicate I don't. But, I'd still like to undeerstand what is going on.
Hollywood5 is offline
post #161 of 433 Old 09-12-2010, 04:33 PM
Hollywood5
Amp
I'm told the metal piece is the amp for the subwoofer. I really don't think I want to replace the Subwoofer if I'm going to get the same thumping noise due to the amp. If I connect up a new subwoofer to the same amp, will I get the same annoying thump?
post #162 of 433 Old 09-12-2010, 05:42 PM
RichardNoggin
im thinkin the thump is due to the cheap paper cone of the stock sub. should sound better with a new one. i just ordered the pyramid so im hoping it sounds good. mine was blown when i bought it so i wont get to compare
post #163 of 433 Old 09-16-2010, 12:34 PM
RichardNoggin
so, i got mine hooked up but it is barely getting power. any ideas? i tried playing with the wires switching them around, but no results. bad amp?
post #164 of 433 Old 09-16-2010, 01:10 PM
RichardNoggin
nevermind. played with the wires some more. i had to use the red and black wire instead of the black and gray
post #165 of 433 Old 09-16-2010, 07:41 PM
RichardNoggin
man what an improvement that pyramid is. so happy
Factory subwoofer mpeak Audio, CB & Ham Radios, GPS, & Electrical 1 04-12-2007 03:22 PM
Good subwoofer to replace stock. jreuscher Audio, CB & Ham Radios, GPS, & Electrical 5 12-19-2006 08:58 AM
factory subwoofer help please!!!!!!! wrangler8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-31-2005 03:30 AM
Factory Subwoofer- need some help Xtreme04 Audio, CB & Ham Radios, GPS, & Electrical 7 12-29-2004 09:45 AM
factory subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 2 10-03-2002 04:56 PM
