How To Replace The Factory Subwoofer - Page 10 - JeepForum.com
 2Likes
post #136 of 433 Old 07-31-2010, 06:43 PM
SCDolphin
SCDolphin's Avatar
Speakers
Is it common to use 1 ohm speakers in other cars. I thought most speakers were 4 o 8 ohms?
2013 Rubicon Unlimited
Hardtop/softtop
Ham W4DRH
SCDolphin is offline
post #137 of 433 Old 08-01-2010, 08:31 AM
SirGCal
RIP
SirGCal's Avatar
As an OEM rule, there is no commonality... I've seen them use from 1/2-ohm all the way through 6, 12, and even 16 ohm speakers or speaker setups in different vehicles...
The 'standard' for aftermarket automotive is 4-ohms and home audio is 8-ohms. But then again that's just a starting point.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #138 of 433 Old 08-04-2010, 12:54 PM
TJe0454
TJe0454 is offline
post #139 of 433 Old 08-12-2010, 07:23 PM
JOliverGraham
Dear Original Poster,
I just finished the install. With one minor slip up with the sub I received. Red was +, Black was -.
Either way, the writeup with associated photos worked like a charm. Even down to the comment about "Enjoy your mediocre sub"
Thanks!
2003 Rubicon named Jackie, short for "Jackalope" -- www.wi4x4.com
JOliverGraham is offline
post #140 of 433 Old 08-12-2010, 07:49 PM Thread Starter
ArcherAce
Thanks!
Glad i could help
l_______
/l ,[_____],
l---L -
OlllllllO-
()_) ()_)--o-)_)
Aerodynamics are overrated
ArcherAce is online now
post #141 of 433 Old 08-17-2010, 07:10 PM
lactrain
Originally Posted by gjeppesen View Post
OK. Old post, but a question was never clearly answered. How do you get from 4 wires to 2?
My only guess, based on my research is if the OEM amp is Mono 1 Ohm and the OEM sub was a dual (two voice coils) 2 ohm and maybe it was bridged down so the sub would run at 1 ohm. My guess to why there are so many wiring combinations.
Mono/1-channel amplifiers that have two (2) sets of speaker outputs that are actually connected as one (1) inside the amplifier. What this means is that the 2 sets of different speaker outputs on the outside of the mono amplifier are actually only acting as one inside the amplifier (If you can understand, I'm sure you can!).
~ Diagram ~
Just a guess.
I havent quite did the install yet still figuring out what to buy .... So far it looks like
Polk Audio DB461 - Dash
Polk Audio DB521 - Sound Bar
The reason im going with the Polks is
a. The specs match the OEM
b. They are certified for marine use
c. They seem to have good reviews
And all signs are pointing to the .....
Kicker - 10CVT652
.....Basically a 2010 version of the 2 Ohm 6.5 low profile Sub.
LACTRAINS 05 RUBICON
USA
lactrain is offline
post #142 of 433 Old 08-17-2010, 08:01 PM
SirGCal
RIP
SirGCal's Avatar
~ Diagram ~
Just a guess.
Kicker - 10CVT652
NONO!! For a TJ, get two pair of DB521's. Do NOT put 4x6's back in the dash...
SirGCal is offline
post #143 of 433 Old 08-18-2010, 12:08 AM
lactrain
Where can I purchase the adapter????? And will there be any modifications to the dash to fit these 51/4" speakers?
USA
lactrain is offline
post #144 of 433 Old 08-18-2010, 08:36 AM
SirGCal
RIP
SirGCal's Avatar
In 2005, no mods necessary. The adapter can be had at any number of places. But I prefer to make my own. There's templates floating around.
SirGCal is offline
post #145 of 433 Old 08-18-2010, 09:22 AM
lactrain
I found them ..... Car-Speaker-Adapters.com
USA
lactrain is offline
post #146 of 433 Old 08-19-2010, 11:02 AM
lactrain
I found another sub similiar in specs to the oem just not sure if it will fit in the center console. Hoping you all with experience can take a look at the size and let me know if you all think i can mod it in.
Elemental Designs
Model Name : e3.6 Subwoofer
Available Voice Coils : Dual 2
Power Handling : 50/200 WRms
USA
lactrain is offline
post #147 of 433 Old 08-26-2010, 07:56 PM
tchaap
I've got 4" in my dash?
Sir G, great info on these posts, Thanks!
I just got my 03 rubicon about a month ago and am slowly cracking it open to see what was changed. The speakers have all sounded "small". Pulled off my front panels after reading this post and found 4" round alpines installed. Does the adapter you mention allow for 5 1/4 speakers in this front area?
Also, just cruious as I'm not an audio expert by any means...why no 4 X 6? Is 5 1/4 just a better speaker?
Thanks,
TC
tchaap is offline
post #148 of 433 Old 08-26-2010, 09:19 PM
SirGCal
RIP
SirGCal's Avatar
Thanks,
TC
Yes, and yes... Simply put, they fit. And the 5.25" size is a sweet spot for full-range speakers for powerful yet clean sound. You'll get a warmer, fuller sound than a 4x6 or 4" plate speaker.
SirGCal is offline
post #149 of 433 Old 08-27-2010, 04:01 PM
AZG23
SirGCal.......you have mentioned beefing up the stock plastic box...what would you recommend to do that? I will be adding polyfil...but wondered what else could be done
Brad B.
"If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick."
AZG23 is offline
post #150 of 433 Old 08-27-2010, 08:02 PM
SirGCal
RIP
SirGCal's Avatar
Lining it with a layer of fiberglass can work wonders. Or at least some sound-material. (Dynamat). The goal is to make it more rigid and reduce pinging. The poor-man's route would be at least rubberized undercoating on the inside of the box. It's not great but better than nothing and will help reduce the pinging of the plastic box.
SirGCal is offline
Factory subwoofer mpeak Audio, CB & Ham Radios, GPS, & Electrical 1 04-12-2007 03:22 PM
Good subwoofer to replace stock. jreuscher Audio, CB & Ham Radios, GPS, & Electrical 5 12-19-2006 08:58 AM
factory subwoofer help please!!!!!!! wrangler8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-31-2005 03:30 AM
Factory Subwoofer- need some help Xtreme04 Audio, CB & Ham Radios, GPS, & Electrical 7 12-29-2004 09:45 AM
factory subwoofer razor Audio, CB & Ham Radios, GPS, & Electrical 2 10-03-2002 04:56 PM
