How hard is it to install a sub/ - JeepForum.com
post #1 of 5 Old 08-14-2005, 01:10 AM Thread Starter
EJames1226
EJames1226's Avatar
If i were to buy a sub, how hard would it be for me to install it on my own?
If i have instructions on how to do it, i can usually do it, but im a complete noob to electrical. I replaced the battery and air filter on my own though, if that counts.
Oh, i can also hook up my home stereo.
Should i try it or just let circuit city or somewhere do it?
EJames1226 is offline
post #2 of 5 Old 08-14-2005, 08:54 AM
method84
method84's Avatar
save the money youd spend on having some high school dropout do it at best buy or circuit city and do it yourself. Its really not all that bad...and if you buy your stuff through crutchfield they give detailed insturctions on what to do...But you really dont need them...All you really have to do it run a power wire from your battery all the way to your amp location and tuck it away as you go...Then you have to run a turn-on lead from the back of your headunit all the way to the amp location. Then while you are in the back of the head unit you have to run two RCA patch cables from the pre-outs on your headunit all the way back to the amp but tucked away on the seperate side of the vehicle...After thats done you have to run a ground wire from your amp to a good chasis ground on your jeep...I choose the seat brackets...After you have those wires ran, turn on your jeep and your amp should turn on when the head unit is on (turn-on lead). Now that the amps hooked up all you have to do is run two wires from your sub to the terminal cup, screw the sub to the box, run speaker wire from the terminal cup to the amp and walla you are all hooked up...I sounds like a lot but its a real easy thing to do...If you want more detailed insturctions and pictures I think crutchfield has them on their website under tech or something (http://www.crutchfield.com).....good luck
method84 is offline
post #3 of 5 Old 08-14-2005, 06:18 PM
NEWtoTHEjeepLIF
Very true, if you consider it a mod..... it is close to the easiest you will ever do on your jeep!
NEWtoTHEjeepLIF is offline
post #4 of 5 Old 08-15-2005, 11:17 PM Thread Starter
EJames1226
EJames1226's Avatar
Ok cool, im gonna research it alot more.
Heres a question. Should i build a speaker box for it? or should i just buy one off the net, like ebay or something?
P.S. Awesome avi method84
Edit: Wich one of these under the 150 price range would be good for rock/metal, and easy to install, if it matters? Do you need to know what kind of cd player i have installed?
post #5 of 5 Old 08-15-2005, 11:47 PM
zolon
zolon's Avatar
Word of advice if you want.. but run positive and negative in fused links for your head unit and your amp to the battery.. From everything I have been reading about jeeps, and my past expereince with putting stereos in cars, you will be happy you did this in the long run.
2012 Jeep Wrangler Sport - Silver - Build Date 2-27-2012
1999 Safari Zanzibar 38' Diesel Pusher (Full Time Home)
zolon is offline
Is it hard to install an exhaust? dickensheets Fabrication Shop 5 04-27-2008 02:47 PM
How hard is it to install truetrac your self pete1182 Engines & Drivetrain 5 02-19-2007 03:13 PM
are lifts hard to install? atamata Tires & Wheels 10 01-23-2007 07:22 PM
RE Long Arm Install Questions Very Hard johnny1720 Tires & Wheels 7 11-03-2004 10:44 PM
How hard to install Full Length AAL? Jeep Cherokee Tires & Wheels 1 02-02-2004 11:45 AM
