how do I get to the switch panel in my tj - JeepForum.com
post #1 of 4 Old 11-28-2008, 07:54 PM Thread Starter
bandit455
Tj how do I get to the switch panel in my tj
I have searched but no success
so how do i run the wire to the switch that came with my hella 500ff's into the switch panel?
If anyone has a write up on this that would be great
bandit455 is offline
post #2 of 4 Old 11-28-2008, 09:42 PM
rpg1520
Heavily Armed Liberal
I ran the wires on mine thru the rubber seal on the drivers side and over to the switch. You can see this seal by looking on the drivers side of the engine compartment under the tray that holds the anti-lock brakes. I just drilled a small hole thru it the size of the wires. I also used the cig. lighter wire for power because it's a switched power source and it's right there where the Hella light switch will be installed.
rpg1520 is offline
post #3 of 4 Old 11-29-2008, 07:58 PM Thread Starter
bandit455
Thanks I m considering just putting it in front of the t-case lever because it's right near that center firewall grommet.
post #4 of 4 Old 11-30-2008, 07:44 AM
ImaginaryFriend
ImaginaryFriend's Avatar
Originally Posted by rpg1520 View Post
I ran the wires on mine thru the rubber seal on the drivers side...
x2
I have several wires running through that spot. Wires for the switches (to relays) for 3 sets of lights and cb power/ground. Plenty of room for more.
I'm not familiar with the grommet near the T-case. I found the driver's side grommet, it is easily accessible, so I went that route without searching further.
Good luck wherever you run 'em.
ImaginaryFriend is offline
My New YJ switch panel that I'm working on 92 Green YJ Audio, CB & Ham Radios, GPS, & Electrical 6 03-01-2012 05:51 PM
Switch Panel Design Scotch740 Fabrication Shop 21 09-24-2009 11:45 AM
My switch panel Comanche_ General Jeep & Off-Road Equipment 0 08-29-2008 01:34 AM
Aux switch panel... neZZr Audio, CB & Ham Radios, GPS, & Electrical 21 05-16-2006 02:14 PM
TJ switch panel CETROV Fabrication Shop 1 06-15-2004 04:25 PM
