How did you make YOUR cb safe? - JeepForum.com
post #1 of 7 Old 02-11-2004, 06:37 PM Thread Starter
Killer Angel
I hear about CB's getting stolen all the time. I was wonder how you guys made your CB safe inside your Jeep (other than the tuffy consoles / overhead boxes.)
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
3 1/2" Suspension Lift
1 or 2" Body Lift
Killer Angel is offline
post #2 of 7 Old 02-12-2004, 07:14 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
First try to hide it, second give it some armor. I've seen a few pics of people here that use metal, sheet, diamond, whatever. It all really depends where you have it mounted. If you have it laying on your seat, good luck. If its in your dash, you can use the metal, cut a recatngler hole big enough for the cb, and than mount the metal to something in the dash. It's till easy to steal, but makes it much harder than most applications. If the perp really wants it, he'll get it.
So where do you have or plan to have your mounted.
Matt
MSHarnett is offline
post #3 of 7 Old 02-12-2004, 07:19 PM
Renegade_Rick
Renegade_Rick's Avatar
Simple put in one of thouse hidden Cb radios where you can mount the radio under the seat and control all the functions with the mic. Heck you could even hide it in your lockable glove box and simply drill a small hole for the mic cable. Of course you'd haft to run a small external speaker as well but it would be cheaper than a spendy tuffy.
1999, Sport, 4-door, 4L-I6, AW4 auto, np231, 8.25 rear, dana 30 h-p.
Renegade_Rick is offline
post #4 of 7 Old 02-12-2004, 09:30 PM Thread Starter
Killer Angel
I actualy just know thought of an Idea for hiding it. Its not the safest, but you wouldent be able to tell where it was unless you already saw it.
Between the right of the stearing column and the left of the stereo, there is a good bit of room behind the dash. You could have the CB on a small track, or a little swing-out thing that would shove up underneath there. It would be invisible unless you already knew where it was or looked up underneath dash. It would also keep it out of the way. All you would have to do it swing it down when you need it, and swing it back up when you are using it.
Other than that I'm really not sure where to put it.
I'm sure the above idea wouldent be too hard, just someone would have to know how to make it which shouldent be terably hard.
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
1 or 2" Body Lift
post #5 of 7 Old 02-13-2004, 04:27 PM
Bucket110
Bucket110's Avatar
killer...for your idea all you need is a drawer track and maybe some angle brackets....it could be done pretty easily i think.
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
NEJEEPZ
Bucket110 is offline
post #6 of 7 Old 02-13-2004, 06:15 PM Thread Starter
Killer Angel
Yah, a few hinges and a bracket to connect it to the hinges is all you would need. Its actualy an awesome idea now that I think about it. Might have to try something out one I found a CB to buy (dont have 1 yet).
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
1 or 2" Body Lift
post #7 of 7 Old 02-18-2004, 01:46 AM
jamiejeep
jamiejeep's Avatar
Torx bits
I am going to mount mine on a CB rack (www.cbrack.com) I am not sure about vandals damaging it but as for stealing it, I was going to try and find some of those anti-theft Torx screws.
2002 Sport 5-speed
Softop w/half-doors
Remote Start
RE 4.5 SF w/ 3.5 coils
33x12.50 BFG Mud Terrain on 15x8 American Racing Baja
jamiejeep is offline
safe PSI to run on rock ? 89_Jeeper Tires & Wheels 19 05-14-2008 06:40 PM
Safe Transmission WAMPAROO Audio, CB & Ham Radios, GPS, & Electrical 1 02-09-2006 07:54 PM
Safe RPM's??? gumcrew2 Engines & Drivetrain 1 06-27-2005 07:10 PM
Be Safe!!! GrimJeeper91 General Jeep & Off-Road Equipment 29 06-14-2004 02:38 PM
Mud and Water safe? OwnAccord General Jeep & Off-Road Equipment 3 04-11-2004 09:24 PM
