high swr - JeepForum.com
post #1 of 8 Old 08-10-2013, 12:18 PM Thread Starter
snplme21
I bought a uniden 520xl with a fire stick antenna. I set up the cb and the fire stick and my swr is over 3. Tuning the top of the antenna didn't move the swr at all. I grounded the antenna with 12 gauge wiring. Can anyone tell me my issue?
snplme21 is offline
post #2 of 8 Old 08-10-2013, 12:51 PM Thread Starter
snplme21
I had forgotten to attach photos. Idk if they help.
snplme21 is offline
post #3 of 8 Old 08-10-2013, 12:58 PM
04Unlimired
Can someone please tell me how to wire up cobra 29 ltd classic with a 6 foot antenna and wire it correctly I have a plug from the cigarette lighter and I just wanna make sure I'm running the Coax cable the right way and everything
04Unlimired is offline
post #4 of 8 Old 08-10-2013, 01:25 PM
cormizer
So how did this go from helping with a swr to installing a cb system the things you see on this forum lol
cormizer is offline
post #5 of 8 Old 08-10-2013, 10:23 PM
joeyk803c
Clean up that ground you have. That areas looks to be full of crud.
Wire it to the battery with an fuse inline. You can/will get interference if you plug it into the cigarette lighter.
joeyk803c is offline
post #6 of 8 Old 08-10-2013, 10:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I can see that your antenna stud mount is incorrectly assembled, causing the high SWR. When correctly assembled and mounted, there should be no need for an extra "grounding" wire.
The threaded stud goes on top of the bracket.
CJ7-Tim is offline
post #7 of 8 Old 08-10-2013, 10:59 PM
CJ7-Tim
CJ7-Tim's Avatar
...please tell me how to wire up cobra 29 ltd classic
Use the Google and find the Owners Manual with install instructions.
See www.Firestik.com and follow the info in the Tech Help section for CB antenna mounting and CB antenna system problem solving. The info applies to all brands of CB antennas.
CJ7-Tim is offline
post #8 of 8 Old 08-11-2013, 11:38 AM Thread Starter
snplme21
Thanks for the help guys I was able to get the swr just above one. I felt like an idiot...should have read the directions better lol
snplme21 is offline
