High beams dont work - JeepForum.com
post #1 of 6 Old 10-01-2013, 08:35 PM Thread Starter
Jason96XJ
Alright so when I go to turn on my high beams in my jeep my lows turn off and my high beams don't turn on. I checked fuses and all of them are good. Any idea what could be wrong?
Jason96XJ is offline
post #2 of 6 Old 10-02-2013, 10:57 AM Thread Starter
Jason96XJ
Any help would be appreciated
post #3 of 6 Old 10-02-2013, 11:18 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy a $6-15 Volts/Ohms Multi-Meter at your local Hardware store, Home Improvement store, or WalMart type store. Test your Jeep for 12 volts and for ground continuity. Start at the headlight plugs, then check the relay, then check the high beam switch.
If everything check good, test the headlights with 12 volts applied directly to the pins.
CJ7-Tim is offline
post #4 of 6 Old 10-02-2013, 12:41 PM Thread Starter
Jason96XJ
Originally Posted by CJ7-Tim
Buy a $6-15 Volts/Ohms Multi-Meter at your local Hardware store, Home Improvement store, or WalMart type store. Test your Jeep for 12 volts and for ground continuity. Start at the headlight plugs, then check the relay, then check the high beam switch. If everything check good, test the headlights with 12 volts applied directly to the pins.
Thanks for the advice!
post #5 of 6 Old 10-02-2013, 03:46 PM
samlancashire
Not trying to be a smartass but you checked the bulbs, right?
If they're good could be a bad relay. What kind of jeep do you have?
samlancashire is offline
post #6 of 6 Old 10-02-2013, 03:56 PM Thread Starter
Jason96XJ
Originally Posted by samlancashire
Not trying to be a smartass but you checked the bulbs, right? If they're good could be a bad relay. What kind of jeep do you have?
Yea haha I checked. Plus they both stopped working at the same time. It could possibly be a relay I gotta check with the volt meter
